Failed system job relating to storage size statistics
  • 1.  Failed system job relating to storage size statistics
    Posted Dec 31, 2018 10:45 AM
    This job seems to be failing every hour and I am not sure why.  Also, we have been deleting data from our sandbox and prod instances (to manage storage) and the storage space shown in the Power Platform Admin center has not changed to reflect the data we have removed - I assume this is related to this failing system job.  Any ideas?  thanks for your help!  Laura
  • 2.  RE: Failed system job relating to storage size statistics
    Posted Jan 02, 2019 06:46 AM
    No idea but I can confirm that I am seeing the same thing.
  • 3.  RE: Failed system job relating to storage size statistics
    Posted Jan 02, 2019 09:32 AM
    I'm seeing the same thing.  It looks like it started failing 12/14/2018 at 11:35 pm.  I don't see it running, succeeded or failed, prior to that.  I'm online, so I'm guessing they pushed out an update on 12/14.
    Jeff Henry
    Application Manager
    XTRA Lease
    Saint Louis MO
  • 4.  RE: Failed system job relating to storage size statistics
    Posted Jan 07, 2019 02:25 AM
    I can confirm that it started 14.12.2018. in our organization too.
    Zarko Radevic
    Dynamics CRM Programmer
    Digitale Medier 1881 AS
  • 5.  RE: Failed system job relating to storage size statistics
    Posted Jan 06, 2019 11:20 PM
    One of my customers started having issues with disk space and jobs failing. Seems there is a two minute timeout on workflows that I have not encountered before.
    In this process their data grew from 5 gig to 25 gig. I found the system jobs was full of exception data. I kick off a bulk delete of system jobs that had errored and got back to 5gig of disk space.
    Not sure if that helps
    Rick
    Rick Biezen
    Xecutable Pty Limited
  • 6.  RE: Failed system job relating to storage size statistics
    Posted Jan 07, 2019 08:20 AM
    We aren't having the failed system job issue but we have had issues in the past trying to delete data as a way to free up storage space.  A couple years ago we started an automated process for removing old data to keep our storage size down but the size stayed the same and sometimes even grew slightly.  When we contacted Microsoft they advised us that deleting records creates an audit record of that deletion that is approx. equal to and sometimes greater than the size of the record itself so the delete was a wash.  They did advise that after 1 year that audit record is automatically deleted so we'd see the results we were looking for one year after we deleted the record.  I'm not sure if this is what's happening to yours but it was something that caught us off guard so hopefully it helps!
    Nate Varney
    Sr. Software Developer (CRM focused)
    Universal Technical Institute (UTI)
    Scottsdale AZ
  • 7.  RE: Failed system job relating to storage size statistics
    A little late to this but I just finally stumbled on this failed job myself (among other similar failing system jobs). In my searching it would seem that most v9 environments have this issue.
    There was another thread on the Dynamics 365 Community forum where someone posted MS support indicated this is a bug in v9 (the most recent reply).
    Marcus Cadena
    Crow Wing County
    Brainerd, Minnesota
