Update step for pre-operation synchronous plugin issues.
  • 1.  Update step for pre-operation synchronous plugin issues.
    I am getting error for Update step for pre-operation synchronous plugin. Same code runs in update step for post operation asynchronous mode.
    not sure what is the problem error log does not say much. Anybody faced same issue.
    Exception Message: ISV code reduced the open transaction count. Custom plug-ins should not catch exceptions from OrganizationService calls and continue processing.
    ErrorCode: -2146893812
    HexErrorCode: 0x8009000c
    ErrorDetails:
    ApiExceptionSourceKey: Api/PostPipeline
    ApiStepKey: 48e8ee49-3925-eb11-a813-000d3af32f90
    ApiDepthKey: 1
    ApiActivityIdKey: 2437141c-f3d1-48bf-98cb-7677897c65df
    ApiPluginSolutionNameKey: System
    ApiStepSolutionNameKey: System
    ApiExceptionCategory: ClientError
    ApiExceptionMesageName: IsvTransactionCount
    ApiExceptionHttpStatusCode: 400
    HelpLink: http://go.microsoft.com/fwlink/?LinkID=398563&error=Microsoft.Crm.CrmException%3a8009000c&client=platform
    TraceText:
    [Agricorp.FBR.MakeCreditCardPayment: Agricorp.FBR.MakeCreditCardPayment.MakeCreditCardPayment]
    [48e8ee49-3925-eb11-a813-000d3af32f90: Agricorp.FBR.MakeCreditCardPayment.MakeCreditCardPayment: Update of fbr_onlinepayment]
    Activity Id: b62da0a7-a3d7-41f6-9275-2b43e1dfb00d
    Jeebo Mathews
    Agricorp
  • 2.  RE: Update step for pre-operation synchronous plugin issues.
    https://docs.microsoft.com/en-us/powerapps/developer/common-data-service/troubleshoot-plug-in
    Gashaw Feyisa
    CRM Architect
    Russell Investments
    Seattle WA
  • 3.  RE: Update step for pre-operation synchronous plugin issues.
    It looks like there was an exception thrown by an organizationservice request, and your code catches that and continues execution. This will however result in the service being dead, and cannot be used for further execution.
    If it is not possible to identify the problem by checking the code, I would suggest adding some more tracing to the plugin and especially tracing the message of the exception being caught.
    The trace log is then easiest to view using Plugin Trace Viewer in XrmToolBox.
    Jonas Rapp
    MVP
    Sweden
