XRMToolBox
  • 1.  XRMToolBox
    Posted May 13, 2019 01:44 PM
    ​Hello,
    Has anyone been able to get XRMToolBox to connect to Dynamics 365 online Customer Engagement in a GCC Tenant? We have been trying to connect to the XRMToolBox to correct a Fetch XML query and we keep getting the same error message, " Connection Failed:Unable to Login to Dynamics CRM." We have tried connecting with all 3 connection options. Any assistance will be greatly appreciated.
    Sharee Anderson
  • 2.  RE: XRMToolBox
    Posted May 13, 2019 04:05 PM
    Hi Sharee
    By any chance are there any other messages as part of the error, or anything more in the error log?
    EY Kalman
    Senior Manager
    PwC
  • 3.  RE: XRMToolBox
    Posted May 13, 2019 05:35 PM
    Here is the error: We use MFA to authenticate to our environment
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Verbose 16 5/13/2019 9:20:58 AM  Initialize CRM connection Started - AuthType: OAuth
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Information 8 5/13/2019 9:20:58 AM  Using User Specified Server
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Information 8 5/13/2019 9:20:58 AM  Trying Discovery Server, (North America 2) URI is = https://disco.crm9.dynamics.com/XRMServices/2011/Discovery.svc
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Information 8 5/13/2019 9:20:58 AM  DiscoverOrganizations - Called using user of MFA Auth for : https://disco.crm9.dynamics.com/XRMServices/2011/Discovery.svc
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Information 8 5/13/2019 9:20:58 AM  DiscoverOrganizations - Initializing Discovery Server Object with https://disco.crm9.dynamics.com/XRMServices/2011/Discovery.svc
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Information 8 5/13/2019 9:20:59 AM  AuthenticateService - found authority with name https://login.microsoftonline.com/common/oauth2/authorize
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Information 8 5/13/2019 9:20:59 AM  AuthenticateService - found resource with name https://disco.crm9.dynamics.com/
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Verbose 16 5/13/2019 9:20:59 AM  ObtainAccessToken - CRED
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Error 2 5/13/2019 9:21:01 AM  ERROR REQUESTING Token FROM THE Authentication context - General ADAL Error
    Source : Microsoft.IdentityModel.Clients.ActiveDirectory
    Method : RunAsyncTask
    Date : 5/13/2019
    Time : 9:21:01 AM
    Error : Federated service at https://adfs.l3t.com/adfs/services/trust/13/usernamemixed returned error: ID3242: The security token could not be authenticated or authorized.
    Stack Trace : at Microsoft.IdentityModel.Clients.ActiveDirectory.AuthenticationContext.RunAsyncTask[T](Task`1 task)
       at Microsoft.Xrm.Tooling.Connector.CrmWebSvc.ObtainAccessToken(AuthenticationContext authenticationContext, String resource, String clientId, ClientCredentials clientCredentials)
       at Microsoft.Xrm.Tooling.Connector.CrmWebSvc.ExecuteAuthenticateServiceProcess(Uri serviceUrl, ClientCredentials clientCredentials, X509Certificate2 userCert, UserIdentifier user, String clientId, Uri redirectUri, PromptBehavior promptBehavior, String tokenCachePath, Boolean isOnPrem, String authority, Uri& targetServiceUrl, AuthenticationContext& authContext, String& resource, UserIdentifier& userIdent, CrmLogEntry logSink)
    Inner Exception Level 1 :
    Source : System
    Method : GetResponse
    Date : 5/13/2019
    Time : 9:21:01 AM
    Error : The remote server returned an error: (500) Internal Server Error.
    Stack Trace : at System.Net.HttpWebRequest.GetResponse()
       at Microsoft.IdentityModel.Clients.ActiveDirectory.HttpWebRequestWrapper.<GetResponseSyncOrAsync>d__2.MoveNext()
       at Microsoft.IdentityModel.Clients.ActiveDirectory.WsTrustRequest.<SendRequestAsync>d__1.MoveNext()
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Error 2 5/13/2019 9:21:01 AM  Source : Microsoft.IdentityModel.Clients.ActiveDirectory
    Date : 5/13/2019
    Time : 9:21:01 AM
    Source : System
    Date : 5/13/2019
    Time : 9:21:01 AM
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Error 2 5/13/2019 9:21:01 AM  Unable to connect to CRM: The remote server returned an error: (500) Internal Server Error.
    Date : 5/13/2019
    Time : 9:21:01 AM
       at Microsoft.Xrm.Tooling.Connector.CrmWebSvc.DiscoverOrganizations(Uri discoveryServiceUri, ClientCredentials clientCredentials, X509Certificate2 loginCertificate, UserIdentifier user, String clientId, Uri redirectUri, PromptBehavior promptBehavior, String tokenCachePath, Boolean isOnPrem, String authority, CrmLogEntry logSink)
       at Microsoft.Xrm.Tooling.Connector.CrmWebSvc.DiscoverOrganizations(Uri discoveryServiceUri, ClientCredentials clientCredentials, UserIdentifier user, String clientId, Uri redirectUri, PromptBehavior promptBehavior, String tokenCachePath, Boolean isOnPrem, String authority, CrmLogEntry logSink, Boolean useGlobalDisco)
       at Microsoft.Xrm.Tooling.Connector.CrmWebSvc.QueryLiveDiscoveryServer(Uri discoServer, Boolean useGlobal)
       at Microsoft.Xrm.Tooling.Connector.CrmWebSvc.FindCrmOnlineDiscoveryServer(CrmOnlineDiscoveryServers onlineServerList, Boolean useO365Servers)
       at Microsoft.Xrm.Tooling.Connector.CrmWebSvc.InitCRM2011Service()
    Source : System
    Date : 5/13/2019
    Time : 9:21:01 AM
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Error 2 5/13/2019 9:21:01 AM  Unable to Login to Dynamics CRM
    Source : Not Provided
    Method : Not Provided
    Date : 5/13/2019
    Time : 9:21:01 AM
    Error : Unable to Login to Dynamics CRM
    Stack Trace : Not Provided
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Verbose 16 5/13/2019 9:21:01 AM  Initialize CRM connection Started - AuthType: Office365
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Information 8 5/13/2019 9:21:01 AM  Using User Specified Server
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Information 8 5/13/2019 9:21:01 AM  DiscoverOrganizations - Initializing Discovery Server Object with https://disco.crm9.dynamics.com/XRMServices/2011/Discovery.svc
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Verbose 16 5/13/2019 9:21:01 AM  DiscoverOrganizations - attempting to connect to CRM server @ https://disco.crm9.dynamics.com/XRMServices/2011/Discovery.svc
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Verbose 16 5/13/2019 9:21:01 AM  DiscoverOrganizations - created CRM server proxy configuration for https://disco.crm9.dynamics.com/XRMServices/2011/Discovery.svc - duration: 00:00:00.5023814
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Verbose 16 5/13/2019 9:21:01 AM  DiscoverOrganizations - proxy requiring authentication type : OnlineFederation
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Error 2 5/13/2019 9:21:02 AM  Unable to connect to CRM: ID3242: The security token could not be authenticated or authorized.
    Source : System.ServiceModel
    Method : ReadResponse
    Date : 5/13/2019
    Time : 9:21:02 AM
    Error : ID3242: The security token could not be authenticated or authorized.
    Stack Trace : at System.ServiceModel.Security.WSTrustChannel.ReadResponse(Message response)
       at System.ServiceModel.Security.WSTrustChannel.Issue(RequestSecurityToken rst, RequestSecurityTokenResponse& rstr)
       at Microsoft.Xrm.Sdk.Client.ServiceConfiguration`1.Issue(AuthenticationCredentials authenticationCredentials)
       at Microsoft.Xrm.Sdk.Client.ServiceConfiguration`1.AuthenticateInternal(AuthenticationCredentials authenticationCredentials)
       at Microsoft.Xrm.Sdk.Client.ServiceConfiguration`1.AuthenticateWithADFSForOrgId(AuthenticationCredentials authenticationCredentials, Uri identifier)
       at Microsoft.Xrm.Sdk.Client.ServiceConfiguration`1.AuthenticateOnlineFederationInternal(AuthenticationCredentials authenticationCredentials)
       at Microsoft.Xrm.Sdk.Client.ServiceConfiguration`1.Authenticate(AuthenticationCredentials authenticationCredentials)
       at Microsoft.Xrm.Tooling.Connector.CrmWebSvc.ClaimsIFDFailOverAuth[T](IServiceManagement`1 servicecfg, Uri homeRealm, ClientCredentials userCredentials, ClientCredentials deviceCredentials, Int32 depthLevel, Boolean tryNetworkCred)
       at Microsoft.Xrm.Tooling.Connector.CrmWebSvc.CreateAndAuthenticateProxy[T](IServiceManagement`1 servicecfg, Uri ServiceUri, Uri homeRealm, ClientCredentials userCredentials, ClientCredentials deviceCredentials, String LogString, CrmLogEntry logSink)
       at Microsoft.Xrm.Tooling.Connector.CrmWebSvc.DiscoverOrganizations(Uri discoveryServiceUri, Uri homeRealmUri, ClientCredentials clientCredentials, ClientCredentials deviceCredentials, CrmLogEntry logSink)
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Error 2 5/13/2019 9:21:02 AM  Unable to Login to Dynamics CRM
    Date : 5/13/2019
    Time : 9:21:02 AM
    Sharee Anderson
  • 4.  RE: XRMToolBox
    Posted May 13, 2019 06:06 PM
    Thanks Sharee
    Seems to be a problem with ADFS - the line jumping out at me is 'Error : Federated service at https://adfs.l3t.com/adfs/services/trust/13/usernamemixed returned error: ID3242: The security token could not be authenticated or authorized.'
    There was previously an issue with XRM Toolbox (see https://github.com/MscrmTools/XrmToolBox/issues/842). Are you running the latest version of it?
    Also to check, are you using a domain user to try to connect (which has D365 access)?
    EY Kalman
    Senior Manager
    PwC
  • 5.  RE: XRMToolBox
    Posted May 13, 2019 08:15 PM
    XrmToolBox should work in the GCC but MFA can definitely cause issues.  The latest version includes an option for connecting using the SDK Tooling Connector dialog, but even this requires some special steps to get it working.
    Here is the link with the steps to get it working: https://www.xrmtoolbox.com/documentation/for-users/connecting-to-an-organization/#MFAConnection
    James Novak
    Microsoft MVP, Technical Architect
    Futurez Consulting, https://www.futurezconsulting.com
    Springfield VA
  • 6.  RE: XRMToolBox
    Posted May 14, 2019 08:34 AM
    Hi Sharee,
    We've also connected using MFA, and we got it to work by using an App Password. Just leave the MFA box unchecked and enter the app password.
    All the best,
    Nathalie Bahramian
    Data Systems Analyst
    Mennonite Economic Development Associates
    Waterloo ON
  • 7.  RE: XRMToolBox
    Posted May 14, 2019 08:51 AM
    ​We run in a highly similar environment.  The connection string method only works for us once we created an APP (APPID=guid of the app created)  that could be referenced and then included that in our login string.  When the user signs in with this (same for any sandbox instance - we just change the Url address to point to the different sandbox or production), they are presented with a separate Microsoft box to select which credentials to use, and in our case the password (if not on our internal network), and the local certificate to select.  We have been using this environment for almost 2 years now.  There is some good information on how to register an Azure app here: https://community.dynamics.com/crm/f/117/t/245766
    Connection String in ADFS with MFA
    William Suycott
    VP Sales Tools - FIS
    Brown Deer, WI
