Contact Synchronization between Outlook and Dynamics
  • 1.  Contact Synchronization between Outlook and Dynamics
    Posted 18 days ago
    For those that are using Microsoft's out-of-the-box contact synchronization, do you know what the limitations are?  I seem to recall several years ago that Microsoft doesn't have the concept of a "shared" contact and so a single contact can only be connected to a single user.  Our business is very relationship driven where a single contact is often shared or connected to multiple users (think LinkedIn Connections).
    What limitations have you ran into with Microsoft's out-of-the-box contact synchronization?
    Shawn Hickey
    Burns & McDonnell
    Kansas City MO
  • 2.  RE: Contact Synchronization between Outlook and Dynamics
    @Shawn Hickey, check out this tip by @Gus Gonzalez on how to synchronize contacts you follow:
    Niels Lønberg
    Digital Sales Specialist
    Semco Maritime
  • 3.  RE: Contact Synchronization between Outlook and Dynamics
    Some limitations we've encountered:
    • Cannot sync custom fields
    • Limited sync OOB configuration in terms of global system sync setting
      • Default setting is to sync only contacts where the owner is the user
      • This is per a user sync preference setting
    • Contact sync also means task and appointment will sync if there is no configuration adjustment
    Eugene Hoang
    Kavo Kerr Group
    Brea CA
