  • 1.  How can I delete a large number of records
    Posted Nov 23, 2021 04:49 PM
    I have tens of thousands of records (orders and line items) I need to remove from the CRM. The out-of-the-box method is far too limiting, even the XRMToolbox utility limits the deletion to 1k records at a time and won't work. I have over 150k records to remove and I'd like to not spend several days on this task if possible. Is there a method/utility that allows for the removal of over 5k records per run?
    keith courtemanche
    FCS
  • 2.  RE: How can I delete a large number of records
    Posted Nov 24, 2021 02:42 AM
    Yep - good old bulk delete job. Define a view that has the rows you want to delete and run a bulk delete job against it.
    See Dynamics 365 Bulk Delete Jobs - Carl de Souza for the how to.
  • 3.  RE: How can I delete a large number of records
    Posted Nov 24, 2021 12:22 PM
    Hi @Keith Courtemanche,
    Try the Bulk Record Deletion tool in XRMTB from Andy Popkin.
    Ryan Perry
  • 4.  RE: How can I delete a large number of records
    Posted Nov 25, 2021 03:56 AM
    XrmToolBox tool Bulk Data Updater, see more info: https://jonasr.app/bdu/
    It can delete many many records 🙂
    Jonas Rapp
    MVP
    Sweden
