The user authentication failed! Re-Authenticating due to expired token after 12 hours in Dynamics 365
  • 1.  The user authentication failed! Re-Authenticating due to expired token after 12 hours in Dynamics 365
    Posted Jun 01, 2021 02:19 PM
    we are using WCF service which connects to Microsoft dynamic 365 Version 1612(8.2.23.16) on premise. we are using simplified connection as below and we are using two cached connections as we are fetching data from two dynamic servers.
    The .Net framework is 4.6.2
    The references are below
    <package id="Microsoft.CrmSdk.CoreAssemblies" version="9.0.2.34" targetFramework="net462" />
    <package id="Microsoft.CrmSdk.Deployment" version="9.0.2.34" targetFramework="net462" />
    <package id="Microsoft.CrmSdk.Workflow" version="9.0.2.34" targetFramework="net462" />
    <package id="Microsoft.CrmSdk.XrmTooling.CoreAssembly" version="9.1.0.79" targetFramework="net462" />
    <package id="Microsoft.IdentityModel.Clients.ActiveDirectory" version="5.2.9" targetFramework="net462" />
    The service works great for about 12 hours only, but after that we are getting an error as ' The user authentication failed! ' and we notice the below in the CRM logs, the security token expires.
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Information: 8 : Validation of CRM Connection Complete, total duration: 00:00:06.6172066
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Verbose: 16 : New Batch Manager Created, Max #of Batches:50000, Max #of RequestsPerBatch:5000
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Verbose: 16 : Claims Connection Token Debug:
    SecurityToken is Not Null
    Current Time is: 05/30/2021 23:09:47 + 2 Min for ValidFrom Check Only
    Token ValidFrom is 05/30/2021 23:09:40, Is Valid = True
    Token ValidTo is 05/31/2021 11:09:40, Is Valid = True
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Warning: 4 : Claims Connection reset tripped
    Start From is Valid True
    End At is Valid False
    Microsoft.Xrm.Tooling.Connector.CrmServiceClient Warning: 4 : Re-Authenticating due to expired token @ 05/31/2021 07:19:18
    we have used the below coding
    In the webconfig file
      <add name="con1" connectionString="Url=**url**/Orgname;  Domain=domainname;    Username=domainname\***username***; Password=****; AuthType=Office365; RequireNewInstance=True;" />
      <add name="con2" connectionString="Url=**url**/Orgname;  Domain=domainname;    Username=domainname\***username***; Password=****; AuthType=Office365; RequireNewInstance=True;" />
     public OrganizationServiceProxy service;
     var client = CrmServiceClientCache.GetConn(ConfigurationManager.ConnectionStrings["con1"].ConnectionString);
     service = EASclient.OrganizationServiceProxy;
    public static CrmServiceClient Get(string connectionString)
    if (_internalCache.ContainsKey(connectionString)
    && _internalCache[connectionString] != null
    && _internalCache[connectionString].IsReady)
    return _internalCache[connectionString];
    else
    lock (_objLock)
    if (!_internalCache.ContainsKey(connectionString)
    || _internalCache[connectionString] == null
    || !_internalCache[connectionString].IsReady)
    ServicePointManager.SecurityProtocol |= SecurityProtocolType.Tls12;
    CrmServiceClient.MaxConnectionTimeout = new TimeSpan(0, 0, Convert.ToInt32(ConfigurationManager.AppSettings["CrmServiceClientTimeout"]));
    CrmServiceClient crmClient = new CrmServiceClient(connectionString);
    if (crmClient.IsReady)
    _internalCache[connectionString] = crmClient ;
    else
    if (crmClient.LastCrmException != null)
    throw crmClient.LastCrmException;
    throw new InvalidOperationException(crmClient.LastCrmError);
    Why would the security token not renewed automatically. We are looking of the support to get this problem resolved.
    dynacrm Dynacrm
    CFhf
