  • 1.  Bookable Resource Booking - prevent update of End Time
    Posted May 03, 2019 09:16 AM
    I've had a request to modify the behaviour of bookable resource bookings. When the Booking Status is changed from Scheduled to Completed, the End Time is updated to the current time:
    Is there any way to prevent this from happening? It appears to be an out of the box feature of Field Service, so I'm guessing it's coded in to the plugins. I was wondering if there's a preference for this anywhere, but I can't locate it.
    Tom Pickles
    Business Systems Developer
    Visit Scotland
    Edinburgh
  • 2.  RE: Bookable Resource Booking - prevent update of End Time
    Posted Oct 21, 2020 04:54 PM
    Tom,
    Were you able to figure this out? I am trying to find a way to edit the end time when techs/dispatchers forget to close out a WO in a timely fashion. The date/time fields on the Bookable Resource Booking page are locked.
    K Crawford
    National Power
    Raleigh, NC
  • 3.  RE: Bookable Resource Booking - prevent update of End Time
    Posted Oct 22, 2020 12:21 PM
    If you use Google Chrome, there is an extension called "Level Up".  In that extension is a button labeled "God Mode" which will allow you to unlock and edit any locked fields.  That might be worth a shot if your IT department allows you to install extensions in Chrome.
    Level up for Dynamics 365
    Ben Edgren
    Hufcor, Inc
    Janesville WI
  • 4.  RE: Bookable Resource Booking - prevent update of End Time
    Posted Oct 22, 2020 12:54 PM
    Ben,
    I completely forgot that I had that extension and it worked perfectly!!
    Thanks again for your help.
    K Crawford
    National Power
    Raleigh, NC
  • 5.  RE: Bookable Resource Booking - prevent update of End Time
    Posted Oct 22, 2020 01:27 PM
    You're welcome Kim!
    @Tom Pickles I know that is a work-around and not a true answer to your question.  Have you looked into using a workflow or business rule to clear that field and unlock it when/after the booking status changes?  I don't have access to Field Service so it's just a guess on my part.  Hopefully someone else with access can provide a more insightful answer.
    Ben Edgren
    Hufcor, Inc
    Janesville WI
  • 6.  RE: Bookable Resource Booking - prevent update of End Time
    Posted Jun 27, 2022 02:08 PM
    Hi Kim,
    I'm fairly new to D365 CRM, do you remember what you changed so the system would no longer update the end time automatically?
    John
    John Phillips
    Musco Lighting, Inc.
  • 7.  RE: Bookable Resource Booking - prevent update of End Time
    Posted Jun 27, 2022 06:17 PM
    I never found a proper solution. In the end, I hid the system fields for end time and put in custom ones which didn't update automatically. Not really ideal but it worked well enough for our purposes.
    Tom Pickles
    Visit Scotland
    Edinburgh
