Deleting Security Roles
  • 1.  Deleting Security Roles
    Posted Oct 12, 2018 07:56 AM
    Hi all,
    We're on Dynamics 365 Online v9.  We have almost 60 security roles, half of them custom.  I'd like to delete the ones we've effectively "retired" and do not use.  I tried this a few years ago and had problems when doing solution layer migrations so shelved this job but I feel like now is a good time to do it as we have similar named roles and stops any issues of the wrong role being assigned.
    Here are the tasks that I believe need to take place before deleting any security roles...
    • Check that the role isn't attached to a user by running the OOTB User Summary report *
    • Check that the role isn't attached to a team.  I've created a report to show this *
    • Remove permissions from role (unable to remove every permission, it has to have a least one permission.  Leave it with a permission to an entity that isn't part of your unmanaged solution layers)
    • Remove security role from being assigned to each entity Main forms (see below)
    * needs to happen in the source and target environments
    Once the above is done, I am planning to move a solution with the security roles through our environments and then delete the "retired" security roles.
    Feel free to let me know if I'm doing anything wrong or have missed something off.  If anyone has any experience doing this please let me know how you got on.
    Southampton
  • 2.  RE: Deleting Security Roles
    Posted Jan 02, 2019 08:47 AM
    Hi Mark
    Did you try this?
    Just wondering how it went?  We are looking to do something similar.
    James
    James Rees
    Senior Systems Engineer
    Liverpool
  • 3.  RE: Deleting Security Roles
    Posted Jan 08, 2019 08:44 AM
    Edited by Mark Aston Jan 08, 2019 08:44 AM
    @James Rees I have tried it.  In the end I didn't need to worry about the following steps...
    Making sure that the role isn't linked to a user or team is the most important step to do.  You'll also need to do the 2nd step that Aaron mentions about removing the role from the app.  If My Apps is missing from your sitemap, you can add it back in by following these instructions.
    @Aaron Back, MCSE​​ thanks for two points, appreciate it.
  • 4.  RE: Deleting Security Roles
    Posted Jan 08, 2019 09:39 AM
    @Mark Aston - Glad to help! ​
    Aaron Back, MCP
  • 5.  RE: Deleting Security Roles
    Posted Jan 02, 2019 09:31 AM
    @Mark Aston - You may want to check into a couple of things. First, if you go to Customizations and Customize the System, you can scroll down and see Security Roles on the left-hand side. Click this and you will see the list of Security Roles. Select a role in the list and click on "Show Dependencies". This will help you identify anything the role is connected to.
    Second, in the list of dependencies, you may notice a name of an "app" that you may be using since you are on V9. These are the new Model-Driven Apps. To update the security roles tied to these apps, you need to navigate to "Settings" and then "My Apps". This will show you a screen with tiles for each app you have. Select the app and click on the 3 dots and select "Manage Roles". This will pop out a panel on the right-hand side with the Security Roles.
    Aaron Back, MCP
  • 6.  RE: Deleting Security Roles
    Posted Jan 14, 2019 09:51 AM
    Thanks for the help on this we will give it a go.
    James Rees
    Liverpool
