Create Record using Azure Logic App
  • 1.  Create Record using Azure Logic App
    Posted 19 days ago
    Dear All,
    We are currently working on Azure Logic apps and looking forward to create some records in CRM.
    Now we used the connector for Dynamics 365 and pointed to organization and got the entity.
    Now when we try to enter data into the fields it somehow ends of giving up an error message
    An error occurred while validating input parameters: Microsoft.OData.ODataException: Does not support untyped value in non-open type.\r\n at System.Web.OData.Formatter.Deserialization.DeserializationHelpers.ApplyProperty(ODataProperty property, IEdmStructuredTypeReference resourceType, Object resource,
    Having checked into the error it tells that some of the input values provided are not proper.
    Could anyone guide as to how we should enter data in the below field types
    We are looking to populate 4 different fieldtypes
    Currency - This should hold 'US Dollar'
    Potential Client - Name of Company
    Potential Client Type - accounts in our scenario
    Probability - This is an option set field
    Summary - This is a simple text field
    Thank you for your help.
    Bhartendu Pandey
    Willis Towers Watson
  • 2.  RE: Create Record using Azure Logic App
    Posted 19 days ago
    Below is the screenshot of how I am entering the data in the fields
    screen
    still no luck . Need help on the same
    Bhartendu Pandey
  • 3.  RE: Create Record using Azure Logic App
    Bumping the discussion thread .. can anyone help?
    Thank you ​
    Bhartendu Pandey
  • 4.  RE: Create Record using Azure Logic App
    I'm not able to help but I'm interested in your solution.
    I haven't yet seen functions run inline besides the built in 'Expressions' so I'm interested to know how these work.
    DateTimeOffset.Parse()
    (here are a list of date time expressions)
    As for these inline function I haven't seen these work either so I'd handle them a little different.
    accounts()
    transactioncurrencies()
    What I would do is do a dynamics action 'GetRecord' of the transaction currency and a dynamics action 'GetRecord' of the account prior to creating the record.  Use the results of those first two actions to save into the Create a new record action.
    There are a couple different things that I would try when debugging though.
    On your error run you should be able to see an exclamation point and a 'show raw inputs'
    This should at least show you the odata that is attempted to be processed.  You may recognize the error in that.
    Logic Apps have been a lot of trial and error and I haven't seen a lot of great examples out there so it would be great if you could share any insights when you finish.  Thanks!
  • 5.  RE: Create Record using Azure Logic App
    You've made it way too hard for yourself. All you need is the guids in the Currency/Potential Customer fields. The date needs to be in yyyy-mm-dd format. The below worked for me.
    Ben Bartle
    IBM
  • 6.  RE: Create Record using Azure Logic App
    Thank you @Ben Bartle,
    This is great I was able to get the opportunity created :-) .
    Thinking about extending it further is there a way available to dynamically pass values to the logic app using web api
    Bhartendu Pandey
  • 7.  RE: Create Record using Azure Logic App
    Something that I have found useful is to realize that behind the scenes LogicApps is using XRM WebAPI. What this means is that you can figure out the parameters using CRM Rest Builder. And to figure out the parameters, like TransactionCurrency, you can run the RetrieveMultiple and get the values that way.
    Regarding your question about passing parameters to your logicApp, it depends on how you are invoking your LA. If its a HTTP trigger, you can pass values to it, using queryParameters. I wrote a quick post about it: LogicApp-HttpRequest trigger: retrieving query parameters (and more documentation: Call, trigger, or nest workflows with HTTP endpoints - Azure Logic Apps). But just some other ideas, you could trigger the LA using storage queues or Azure Service Bus, where the message contains the data needed to trigger the app.
    Raj Rao
    National CineMedia
    Centennial CO
  • 8.  RE: Create Record using Azure Logic App
    hello @Raj Rao,
    Thank you so much for sharing the details.
    I have installed the solution in my test environment and will look forward to work through it.
    Bhartendu Pandey
  • 9.  RE: Create Record using Azure Logic App
    Another alternative way we can do this is by using Get Data from Dynamics before we create the opportunity and populate any lookup value
    You can populate using pre-fetched data in the create record. And also you can use the dynamic value from the fetched account
    Result
    Hope that helps!
    Aylwin Wijaya
  • 10.  RE: Create Record using Azure Logic App
    Posted 8 days ago
    Hello @Aylwin Wijaya ,
    Thank you for your reply.
    Yes this is something i have learnt. the logic apps and Microsoft ​flow seem to work alike.
    if any data is needed in the next step then we will need to fetch the data in the previous step. I was able to work through this by specifying the Variables for the fields in the JSON body of the HTTPS request header .
    Bhartendu Pandey
