ribbon javascript calling action
  • 1.  ribbon javascript calling action
    Posted 20 days ago
    ​Hi Anyone,
    I am trying to call the custom action from the ribbon button javascript. it throws error not found.
    Below is my code:
    var parameters = {};
    parameters.registrationID = "544916CD-6602-EA11-A811-000D3AF3AC9D";
    var req = new XMLHttpRequest();
    req.open("POST", Xrm.Page.context.getClientUrl() + "/api/data/v9.1/XXXXXX(FC16D1DE-16EE-4ABC-B719-1B734C328A2D)/Microsoft.Dynamics.CRM.XXXXXX", true);
    req.setRequestHeader("OData-MaxVersion", "4.0");
    req.setRequestHeader("OData-Version", "4.0");
    req.setRequestHeader("Accept", "application/json");
    req.setRequestHeader("Content-Type", "application/json; charset=utf-8");
    req.onreadystatechange = function() {
        if (this.readyState === 4) {
            req.onreadystatechange = null;
            if (this.status === 204) {
                //Success - No Return Data - Do Something
            } else {
                Xrm.Utility.alertDialog(this.statusText);
    req.send(JSON.stringify(parameters));
    What I am doing wrong here?
    Jeebo Mathews
    Agricorp
  • 2.  RE: ribbon javascript calling action
    Posted 20 days ago
    Hello Jeebo,
    Can you please post a screenshot of your action and confirm that it is published?
    Andrew Butenko
  • 3.  RE: ribbon javascript calling action
    Posted 19 days ago
    Hi Andrew,
    I am sending you the screenshot of the custom action created.
    It's activated.
    Regards
    Jeebo
  • 4.  RE: ribbon javascript calling action
    Posted 19 days ago
    It's a bit complicated to compare values you removed from code with values in action you removed from the picture. Do you have any problems publishing it without whipping it out?
    Andrew Butenko
  • 5.  RE: ribbon javascript calling action
    Posted 19 days ago
    I have attached the action screenshot with no edit from my side.
  • 6.  RE: ribbon javascript calling action
    Posted 19 days ago
    Thanks! Can I see the code?
    Andrew Butenko
  • 7.  RE: ribbon javascript calling action
    Posted 19 days ago
    The javascript:
    function testButton(selectedRegistrationItems)
           debugger;
                    //if nothing selected or more than 1 registration selected do nothing
                    if(selectedRegistrationItems.length < 0 || selectedRegistrationItems.length > 1)
                       return;
                     var selectedRegistrationGUIDs = '';
                    for (var i = 0; i < selectedRegistrationItems.length; i++) {
                                    selectedRegistrationGUIDs += selectedRegistrationItems[i].Id.replace(/[{}]/g, "") + ";"
            alert(selectedRegistrationGUIDs);
                    //XMLHttpRequest
           //parameters.registrationID = "544916CD-6602-EA11-A811-000D3AF3AC9D";
            parameters.registrationID = selectedRegistrationGUIDs;
           var actionId = "FC16D1DE-16EE-4ABC-B719-1B734C328A2D"
           req.open("POST", Xrm.Page.context.getClientUrl() + "/api/data/v9.1/fbr_registrations("+actionId +")/Microsoft.Dynamics.CRM.fbr_MakePayment", true);
                                                    } else {
  • 8.  RE: ribbon javascript calling action
    Posted 19 days ago
    Thanks! Now it's more or less clear. Where you put action id as a hardcoded guid you should put id of existing fbr_registrationrecord. I see your design - I would recommend to drop this action and recreate it as a global. You can see example here - https://www.inogic.com/blog/2016/10/execute-the-global-action-using-web-api-in-dynamics-crm/
    Andrew Butenko
  • 9.  RE: ribbon javascript calling action
    Posted 19 days ago
    Jeebo
    Try putting this at the first line in your code.
    console.log("Hello")
    If you don't see Hello in your console, then the ribbon cannot find your code.
    Also, have you tried using the new 9.1 WebApi? It is a LOT easier to use than the outdated xhr.
    https://docs.microsoft.com/en-us/powerapps/developer/model-driven-apps/clientapi/reference/xrm-webapi/createrecord
    const customAction = async() => {
        const par = {registrationID: "544916CD-6602-EA11-A811-000D3AF3AC9D"},
            logicalName = "XXXXXX"
        await Xrm.WebApi.createRecord(logicalName, par);
    Rex Kenley Tan, MCSA, MCSD
    Tallmadge OH
  • 10.  RE: ribbon javascript calling action
    Posted 19 days ago
    ​Hi Rex,
    The JavaScript is showing the alert about the current ID selection from the ribbon. So I can confirm the JavaScript is been called.
    Jeebo Mathews
    Agricorp
  • 11.  RE: ribbon javascript calling action
    Posted 19 days ago
    Edited by Rex Kenley Tan 19 days ago
    Jeebo
    Please try this. This is how you should be calling actions with js in v9.1.
    https://docs.microsoft.com/en-us/powerapps/developer/model-driven-apps/clientapi/reference/xrm-webapi/online/execute
    async function testButton(selectedRegistrationItems) {
      try {
        if (selectedRegistrationItems.length !== 1) return;
        const registrationID = selectedRegistrationItems[0].Id.replace(/[{}]/g, ""),
          result = await Xrm.WebApi.online.execute({
            registrationID,
            getMetadata: () => {
              return {
                boundParameter: "fbr_registration",
                parameterTypes: {
                  registrationID: { typeName: "Edm.String", structuralProperty: 1 }
                operationType: 0,
                operationName: "fbr_MakePayment"
        if (result.ok) console.log(`Status: ${result.status} ${result.statusText}`);
      } catch (e) {
        console.error(e.message || e);
    Tallmadge OH
  • 12.  RE: ribbon javascript calling action
    Posted 19 days ago
    Hi Rex,
    Thanks for your reply. If I use WebApi call in JavaScript It is giving me error at the catch. "resource not found for the segment".
    Any clue for this particular error.
    Regards
    Jeebo
  • 13.  RE: ribbon javascript calling action
    Posted 19 days ago
    Jeebo
    Please change boundParameter to (I read the documentation wrong)
    boundParameter: "entity"
    boundParameter: (Optional) String. The name of the bound parameter for the action or function to execute.
    • Specify undefined if you are executing a CRUD request.
    • Specify null if the action or function to execute is not bound to any entity.
    • Specify entity in case the action or function to execute is bound to an entity.
    Tallmadge OH
  • 14.  RE: ribbon javascript calling action
    Posted 19 days ago
    Hi Rex,
    I am getting same error message even after using  "fbr_registrations" for bound parameter
    Regards
    Jeebo
  • 15.  RE: ribbon javascript calling action
    Posted 19 days ago
    Jeebo
    Finally found a decent example for bound actions. You may have to look at your action metadata to get the proper name of your bound entity.
      try {
            registrationID,
              return {
                boundParameter: "entity",
                parameterTypes: {
                  entity: {
                    typeName: "fbr_registration",
                    structuralProperty: 5
                operationType: 0,
      } catch (e) {
    https://carldesouza.com/calling-a-dynamics-365-action-from-javascript-using-xrm-webapi-online-execute/
    Tallmadge OH
  • 16.  RE: ribbon javascript calling action
    Posted 19 days ago
    Hi Rex,
    Thanks Rex. After the code change It giving different error "Cannot read property 'id' of undefined"
    This should be const registrationID issue.
    Not sure why?
    Regards
    Jeebo
  • 17.  RE: ribbon javascript calling action
    Posted 19 days ago
    Jeebo
    I think it is coming from somewhere else. It is complaining about "id" (case sensitive) and the Id in the code has a capital I.
    But just to be sure put a break at console.error. It will stop there if there is something wrong with the code.
    Tallmadge OH
  • 18.  RE: ribbon javascript calling action
    Posted 18 days ago
    ​Hi Rex,
    I used the CRMRestApi to build the WebApi call to the action and it worked.
       debugger;
        return;
    var entity = {};
    entity.id = selectedRegistrationGUIDs;
    entity.entityType = "fbr_registration";
    parameters.entity = entity;
    var fbr_MakePaymentRequest = {
        entity: parameters.entity,
        getMetadata: function() {
            return {
                parameterTypes: {
                    "entity": {
                        "typeName": "mscrm.fbr_registration",
                        "structuralProperty": 5
                operationType: 0,
    Xrm.WebApi.online.execute(fbr_MakePaymentRequest).then(
        function success(result) {
            if (result.ok) {
        function(error) {
            Xrm.Utility.alertDialog(error.message);
    Thanks Rex and Andrew for your help and advice.
    Jeebo Mathews
    Agricorp
