Ribbon Workbench Import into Prod Doesn't Match Dev
  • 1.  Ribbon Workbench Import into Prod Doesn't Match Dev
    Has anyone ran into an issue with the ribbon customization done via the Ribbon Workbench not matching the their Dev environment after exporting to their Prod environment?
    We are On-Prem v8.2 and do all of customization in an unmanaged solution in our Dev environment then export it as managed to put into our Prod environment. This time I modified the ribbon on an entity by moving one custom button and adding a new one. This worked out perfect in Dev, but once I moved the solution Prod the button that I moved is duplicated. The new button is there but because of the duplicate it got pushed into the additional options menu and is not on the ribbon like planned.
    I haven't done to much troubleshooting yet besides some basics (republished solution & cleared browser cache). I figured I'd get this cry for help posted and continue my investigation.
    Russ Morris
    Application Support Analyst
    Avitus Group
    Billings MT
