CRM 2011 installation Error (GrantAspNetServiceAccountAccessAction failed)
  • 1.  CRM 2011 installation Error (GrantAspNetServiceAccountAccessAction failed)
    Posted 24 days ago
    Hello all,
    can anyone help us with this error?
    We are desperately trying to install a CRM2011 Full Server on a MS 2012 R2 Server (also tried 2012 Standard without R2 before) via SHS and config.xml and we get this error.
    The installing User has Access to the Groups and the old, on 2008 R2, installation was also done with this User. For the new installation we are using clean new groups.
    We had an "Account Unknwon" in the OU Groups and deleted it.
    But the error still appears:
    14:03:30|   Info| Installer Complete: DeploymentWebServiceInstaller
    14:03:30|   Info| Installer Start: SdkServerInstaller.Install: operation Repair
    14:03:30|   Info| Executing Install action: Microsoft.Crm.Setup.Server.EnableRoleAssociatedSystemComponentsAction
    14:03:30|   Info| Organization Web Service has an explicit dependency on the following system roles, which will be enabled if not already enabled on the system:  Windows-Identity-Foundation; WCF-HTTP-Activation45; WCF-TCP-PortSharing45
    14:03:30|Verbose| Method entry: Microsoft.Crm.Setup.Common.Utility.DismSystemComponentManager.EnableComponents
    14:03:30|Verbose| Method exit: Microsoft.Crm.Setup.Common.Utility.DismSystemComponentManager.EnableComponents
    14:03:30|   Info| CrmAction execution time; EnableRoleAssociatedSystemComponentsAction; 00:00:00
    14:03:30|   Info| Executing Install action: Microsoft.Crm.Setup.Server.NetTcpPortSharingAction
    14:03:30|   Info| NetTcpPortSharingAction: AspNetServiceAccountName: *\SVC_CRM2011Q_SERV
    14:03:30|   Info| NetTcpPortSharingAction: CrmServiceAccountName: *\SVC_CRM2011Q_ASYNC
    14:03:30|   Info| NetTcpPortSharingAction: SandboxServiceAccountName: *\SVC_CRM2011Q_SB
    14:03:30|   Info| NetTcpPortSharingAction: _accounts.Count: 3
    14:03:30|   Info| NetTcpPortSharingAction: _sids.Count: 3
    14:03:30|   Info| NetTcpPortSharingAction: SMSvcHost.exe process id: 2512
    14:03:30|   Info| NetTcpPortSharingAction: StopService: NetTcpPortSharing
    14:03:30|   Info| NetTcpPortSharingAction: before: controller.Status: Running
    14:03:30|   Info| NetTcpPortSharingAction: stopping service...
    14:03:30|   Info| NetTcpPortSharingAction: after: controller.Status: Stopped
    14:03:30|   Info| NetTcpPortSharingAction: StopService: NetTcpActivator
    14:03:30|Warning| NetTcpPortSharingAction: exception: System.InvalidOperationException: Service NetTcpActivator was not found on computer '.'. ---> System.ComponentModel.Win32Exception: The specified service does not exist as an installed service
       --- End of inner exception stack trace ---
       at System.ServiceProcess.ServiceController.GenerateNames()
       at System.ServiceProcess.ServiceController.get_ServiceName()
       at System.ServiceProcess.ServiceController.GenerateStatus()
       at System.ServiceProcess.ServiceController.get_Status()
       at Microsoft.Crm.Setup.Server.NetTcpPortSharingAction.StopService(String serviceName)
    14:03:30|   Info| NetTcpPortSharingAction: StopService: NetPipeActivator
    14:03:30|Warning| NetTcpPortSharingAction: exception: System.InvalidOperationException: Service NetPipeActivator was not found on computer '.'. ---> System.ComponentModel.Win32Exception: The specified service does not exist as an installed service
    14:03:30|   Info| NetTcpPortSharingAction: StopService: NetMsmqActivator
    14:03:30|Warning| NetTcpPortSharingAction: exception: System.InvalidOperationException: Service NetMsmqActivator was not found on computer '.'. ---> System.ComponentModel.Win32Exception: The specified service does not exist as an installed service
    14:03:30|   Info| NetTcpPortSharingAction: configFile: C:\WINDOWS\Microsoft.NET\Framework64\v4.0.30319\SMSvcHost.exe.config
    14:03:30|   Info| NetTcpPortSharingAction: SMSvcHost.exe.config successfully updated
    14:03:30|   Info| NetTcpPortSharingAction: StartService: NetTcpPortSharing
    14:03:30|   Info| NetTcpPortSharingAction: before: controller.Status: Stopped
    14:03:30|   Info| NetTcpPortSharingAction: SMSvcHost.exe process id: 5072
    14:03:30|   Info| CrmAction execution time; NetTcpPortSharingAction; 00:00:00.4788358
    14:03:30|   Info| Executing Install action: Microsoft.Crm.Setup.Server.RegisterSdkServerSandboxClientAction
    14:03:30|   Info| Registering performance counters for Sandbox Client
    14:03:31|   Info| CrmAction execution time; RegisterSdkServerSandboxClientAction; 00:00:00.7117716
    14:03:31|   Info| Executing Install action: Microsoft.Crm.Setup.Server.SetMetadataFileSecurityAction
    14:03:31|   Info| CrmAction execution time; SetMetadataFileSecurityAction; 00:00:00.2976851
    14:03:31|   Info| Executing Install action: Microsoft.Crm.Setup.Server.CreateOfflineDataFolderAction
    14:03:31|   Info| CrmAction execution time; CreateOfflineDataFolderAction; 00:00:00
    14:03:31|   Info| Executing Install action: Microsoft.Crm.Setup.Server.WriteLocalSdkPortAction
    14:03:31|   Info| CrmAction execution time; WriteLocalSdkPortAction; 00:00:00
    14:03:31|   Info| Executing Install action: Microsoft.Crm.Setup.Server.CreatePluginAssemblyFolder
    14:03:31|   Info| CreatePluginAssemblyFolder: Sandbox: assemblyAbsolutePath: c:\Program Files\Microsoft Dynamics CRM\Server\bin\assembly
    14:03:31|   Info| CreatePluginAssemblyFolder: Sandbox: SandboxServiceAccountName: *\SVC_CRM2011Q_SB
    14:03:31|   Info| CrmAction execution time; CreatePluginAssemblyFolder; 00:00:00.0148346
    14:03:31|   Info| Executing Install action: Microsoft.Crm.Setup.Server.UpdateSDKEndpointsAction
    14:03:32|   Info| CrmAction execution time; UpdateSDKEndpointsAction; 00:00:00.1125045
    14:03:32|   Info| Executing Install action: Microsoft.Crm.Setup.Server.AddAspNetServiceAccountToPrivilegedUserGroupAction
    14:03:32|Verbose| Adding account *\SVC_CRM2011Q_SERV to group LDAP://*.ads.*.de/CN=PrivUserGroup CRM2011Q,OU=Quality,OU=DE-DO-CRM2011,OU=Service Accounts,OU=*,OU=* AG,OU=DE,DC=ads,DC=*,DC=de ...
    14:03:32|   Info| Account network name: *\SVC_CRM2011Q_SERV
    14:03:32|   Info| Account CN=svc_crm2011Q_serv,OU=Quality,OU=DE-DO-CRM2011,OU=Service Accounts,OU=*,OU=* AG,OU=DE,DC=ads,DC=*,DC=de added to group LDAP://*.ads.*.de/CN=PrivUserGroup CRM2011Q,OU=Quality,OU=DE-DO-CRM2011,OU=Service Accounts,OU=*,OU=* AG,OU=DE,DC=ads,DC=*,DC=de.
    14:03:32|   Info| CrmAction execution time; AddAspNetServiceAccountToPrivilegedUserGroupAction; 00:00:00
    14:03:32|   Info| Executing Install action: Microsoft.Crm.Setup.Server.GrantAspNetServiceAccountAccessAction
    14:03:32|  Error| System.Exception: Action Microsoft.Crm.Setup.Server.GrantAspNetServiceAccountAccessAction failed. ---> System.ArgumentException: The parameter is incorrect.
       at System.DirectoryServices.Interop.UnsafeNativeMethods.IAds.PutEx(Int32 lnControlCode, String bstrName, Object vProp)
       at System.DirectoryServices.PropertyValueCollection.set_Value(Object value)
       at Microsoft.Crm.Setup.Server.Utility.ADUtility.GrantAccess(DirectoryEntry groupEntry, String accountName)
       at Microsoft.Crm.Setup.Server.GrantAccessToServiceAcountAction.Do(IDictionary parameters)
       at Microsoft.Crm.Setup.Common.CrmAction.ExecuteAction(CrmAction action, IDictionary parameters, Boolean undo)
       --- End of inner exception stack trace ---, Error, RetryCancel, Option1
    14:09:41|   Info| InputResult: Cancel
    14:09:41|   Info| CrmAction execution time; GrantAspNetServiceAccountAccessAction; 00:06:09.0471570
    14:09:41|  Error| Installer Complete: SdkServerInstaller - Error encountered
    Does anyone know how to solve this?
    greetings
    Maik
    Maik Luis
    CRM Support Specialist
  • 2.  RE: CRM 2011 installation Error (GrantAspNetServiceAccountAccessAction failed)
    Posted 24 days ago
    HI,
    Are you using new Service accounts for the new install? If so are they all part of the local server Performace Lof Users group?
    Krishna Jacques
    CRM Specialist
    Rumsey Electric Company
    conshohocken PA
  • 3.  RE: CRM 2011 installation Error (GrantAspNetServiceAccountAccessAction failed)
    Posted 24 days ago
    Edited by Maik Luis 24 days ago
    we are using the old Service Account (which at the Moment are running fine for the Testsystem on 2008R2 Server), but created new Groups.
    Trying to do a new installation on Server 2012.
    We have added the Async- and Service-Account to the Performance Log Group (this Error appeared earlier).
    Do the Sandbox and Deployment User also be in there ?
    greetings
    Maik
    Maik Luis
  • 4.  RE: CRM 2011 installation Error (GrantAspNetServiceAccountAccessAction failed)
    Posted 24 days ago
    I have them all as part of the Performance log group. I does not hurt to try.
    Krishna Jacques
    CRM Specialist
    conshohocken PA
  • 5.  RE: CRM 2011 installation Error (GrantAspNetServiceAccountAccessAction failed)
    Posted 24 days ago
    CRM 2011 is supported with UR13 only with Windows Server 2012.
    Windows Server 2012 Datacenter or Standard CRM
    Update Rollup 13
    https://support.microsoft.com/en-us/help/3005163/compatibility-with-microsoft-dynamics-crm-2011
    When I typically see this error it has been related to the OS version not being compatible.
    Teresa Hagman
    Technical Advisor
    Microsoft
    Redmond WA
  • 6.  RE: CRM 2011 installation Error (GrantAspNetServiceAccountAccessAction failed)
    Posted 23 days ago
    As i said, we tried this installation (via SHS and config file) on a 2012 Standard Server and ran into the same error.
     <Patch update="true">C:\install\2_CRM 2011 Basic Server\SHS\Server_KB2434455_amd64_1033.msp</Patch>
    I added now all Users (async, sandbox, deployment, service) to Performance Log, but that didn't help :(
    Maik Luis
  • 7.  RE: CRM 2011 installation Error (GrantAspNetServiceAccountAccessAction failed)
    We seem to have been relating this due to "Account unknown" being present on CRM OU but we couldn't yet understand why.
    If they are removed, normally this error is avoided.
    Pedro Freitas
    Microsoft
    Redmond WA
