CRM reports exported to word is not formated properly.
  • 1.  CRM reports exported to word is not formated properly.
    Posted Feb 04, 2019 11:48 AM
    ​when I run the report in CRM everything looks good but as soon as I export the report to MS word tables seems not aligned to each other. Has anyone faced this issue and has a solution?
    Jeebo Mathews
    Agricorp
  • 2.  RE: CRM reports exported to word is not formated properly.
    Posted Feb 05, 2019 09:40 AM
    Hi Jeebo,
    That used to be a significant complaint with exporting reports to Word until one of my team found a solution to remove the tables from the report which leaves the report formatted as designed without the tables.
    Download the report as a PDF file and save, then open Word and open the saved PDF file from Word. Word will convert it to .docx and the tables will be eliminated. It is a few extra steps, but a lot fewer than removing the tables from the report when downloading directly to Word.
    Jim​
    Jim Wooldridge
    Sr. Analyst
    Salt River Project
    Tempe AZ
