Create form fields (D365 Marketing) without having to map to CRM Contact/Lead Field
  • 1.  Create form fields (D365 Marketing) without having to map to CRM Contact/Lead Field
    Posted 19 days ago
    #CustomerEngagement #Marketing- Need help on Dynamics Marketing.
    Any workaround on creating a form field without having it to be mapped to a contact/lead field? Our customer is not keen on having to do the two step approach of creating CRM field and then a form field and having to map each other. They wish to post few questions on the form (which does not have to be created/mapped against a contact/lead)​ or if this is a limitation, how easily they can create fields in CRM that can be hidden?​
    Veena Ravindran
  • 2.  RE: Create form fields (D365 Marketing) without having to map to CRM Contact/Lead Field
    Posted 18 days ago
    I think we need a little more information as to what is driving this requirement, but you can't add fields to an entity that are not associated with a entity - the data has to be stored somewhere.
    Using business rules, you can add fields that appear (or are hidden) depending on something selected in another field.
  • 3.  RE: Create form fields (D365 Marketing) without having to map to CRM Contact/Lead Field
    Posted 18 days ago
    Let me explain the business background to this.
    The customer would like to create just the form fields without mapping the same to a CRM field for the following reasons:
    1. Ease of creation of form fields (like how click dimensions work)
    2. They fear that if they need to create fields on contact/lead for every form field, they might even run out of fields against this entity
    They use the form fields to create questions (text fields) which will be posted on a form and they do keep changing the questions quite often. Hence if they have to create a CRM field against every form field, it will be quite cumbersome.
    They would like to just analyse the values submitted by contacts/leads, without really mapping to CRM fields (similar to click dimensions).
    Any workaround on this?
    Veena Ravindran
  • 4.  RE: Create form fields (D365 Marketing) without having to map to CRM Contact/Lead Field
    Posted 18 days ago
    I don't think Click Dimensions does this - where is the data stored?
    When is the data being collected?
    I would suggest maybe looking at Forms Pro (or Voice of the Customer - which would be better but is being deprecated).
  • 5.  RE: Create form fields (D365 Marketing) without having to map to CRM Contact/Lead Field
    Posted 18 days ago
    Yes, click dimensions let you create form fields without having to mandatory map to a contact/lead field. Data must be stored on CD Azure.
    I tested it out and it does let me save form fields without having to map to a CRM field necessarily. When the form is submitted, the "Posted Fields" and "Posted Form" entity shows the data as well.
    Veena Ravindran
  • 6.  RE: Create form fields (D365 Marketing) without having to map to CRM Contact/Lead Field
    Posted 18 days ago
    Forms Pro is a good suggestion though.
    Veena Ravindran
