Form issues after UI update
  • 1.  Form issues after UI update
    Posted 20 days ago
    I had one of my environments upgrade to the United Interface over the weekend. And while the transition was pretty dang smooth, I have a form that now won't behave correctly.
    It's rendering a large area of white space in the middle of the form. I have checked for spacers, hidden fields, everything I can think of that may be causing this, with no luck. I've tried the new and old form editors and while other changes are happening when I make them, nothing I do will make this white square go away. It's pushing down the other fields like there is a tab or placeholder there.
    Any ideas on how to get rid of this? Do I need to go into the XML and edit it?
    Toni Galata
    Dynamics Administrator
  • 2.  RE: Form issues after UI update
    Posted 20 days ago
    Toni -
    If you have the composite address field on the form, try replacing it with the individual address fields - or the other way around.
