Existing Contact and Existing Account on Leads form
  • 1.  Existing Contact and Existing Account on Leads form
    Posted 20 days ago
    We're on D365 CE Online v9 and I've been asked to investigate the following requirements for the Leads form.
    1) Selecting a contact that is related to the selected account
    When Existing Account is populated on the Lead to Opportunity Sales Process BPF, a user can select any contact in the CRM.
    Is it possible to replicate the functionality on the Opportunity form where the Account is populated and then the Contacts that can be selected are filtered by related company (see below screenshot from the Opportunity form)?  For info, the Existing Contact field doesn't appear to be available in the Lead entity, its only available on the BPF.
    2) Auto populate fields from selected Contact
    When Existing Contact is populated it brings across fields from the Contact record (e.g. Name, Job Title, Business Phone etc) as per the 2nd bullet point on this Microsoft article.  It is possible to also bring across the Address fields from the Contact?  I've looked at the Contact and Lead relationships but I can't see that the existing functionality is available to view/amend (e.g. as mappings between the entities).
    3) Auto populate fields from selected Account
    Following on from the above, is it possible to replicate this same functionality to bring across fields from the account when Existing Account is populated?
    Any advice would be appreciated.
    #Admin
    Engineer
  • 2.  RE: Existing Contact and Existing Account on Leads form
    Posted 20 days ago
    Hey Mark,
    All three of these can be accomplished via Javascript where you can filter the lookup related to the selected Account and then you can populate values based on the selected contact/account. Thanks!
    Doug Apicella
    Solution Architect
    Greenville SC
  • 3.  RE: Existing Contact and Existing Account on Leads form
    Posted 18 days ago
    Thanks for the reply @Doug Apicella.  I've solved the first point.  Existing Contact is available to add to the Lead form, the field is called Parent Contact for Lead.  By adding this field, I can then set the Related Records Filtering properties which gives the same functionality as per the Opportunity form so that when I select an account, only the contacts that relate to the selected account can be chosen.
    For points 2 and 3, we'll look at whether we map the fields as per this article as we'd prefer to have a non code solution as we have limited developer resource.
    Engineer
  • 4.  RE: Existing Contact and Existing Account on Leads form
    Posted 18 days ago
    Hey Mark, excellent on point 1! I didn't realize that functionality was available on the lookup very cool and thanks for the lesson! Regarding the field mapping it only applies to creating related records from a given entity. So if you create a contact from an account the account -> contact field mappings will carry over. This can't be used to populate fields on a form when selecting a given record in a lookup. Unfortunately you cannot use oob business rules to set field value's from related records either. As far as I know js has always been what we've had to do. Thanks!
    Doug Apicella
    Solution Architect
    Greenville SC
  • 5.  RE: Existing Contact and Existing Account on Leads form
    Posted 18 days ago
    Thanks for the clarification about mapping entity fields.  I'll get back to the person who requested the change and let them know that js looks to be the only way to do points 2 and 3.
    Engineer
