Registering and Configure the SPA application through adal.js
  • 1.  Registering and Configure the SPA application through adal.js
    Posted 23 days ago
    ​Hi All,
    After registering/configuring SPA application in Azure Active Directory with adal.js. when I run the SPA application after login it throws
    AADSTS700054: response_type 'id_token' is not enabled for the application. Trace ID: ff6bc368-d3f2-40b7-a56f-6f041b7d0700 Correlation ID: 69cbfe92-727d-4172-863a-bf6e3eae3c6a Timestamp: 2019-08-30 19:25:25Z.
    Not sure how I can enable the id_token for the application?
    anybody who faced same or similar issue?
    Regards
    Jeebo Mathews
    Agricorp
