Dynamics 365 – Model driven Apps
  • 1.  Dynamics 365 – Model driven Apps
    Posted Sep 16, 2019 12:45 PM
    I have a 3rd Party Web API and want to display the API data in the Model Driven App. Is it possible to do the same using webhook or plugin and what will the approach for the same.
    #CRM2016#PowerApps#CRM2016 #Focus-D365UG/CRMUG
    Charles Nadar
    Willis Towers Watson
  • 2.  RE: Dynamics 365 – Model driven Apps
    Posted Sep 17, 2019 11:26 AM
    Have you looked at Virtual Entities? They might be the right direction for you. Also you can create web resources that can call on web resources (webhook and such).
    Nicholas Anderson
    Information Technology
    Wagstaff Inc.
    Spokane WA
  • 3.  RE: Dynamics 365 – Model driven Apps
    Posted Sep 18, 2019 01:53 AM
    Webhook and Plugin in Dynamics are reacting to things that happen inside the system, so they would be rather used to send the data to en external API.
    As Nicholas says, you should look at Virtual entities or build an html web resource which gets the data on load via JavaScript.
    Zarko Radevic
    Dynamics CRM Programmer
    Digitale Medier 1881 AS
