DateTime field attribute DataOnly adds time to database
  • 1.  DateTime field attribute DataOnly adds time to database
    Posted Feb 05, 2019 03:53 PM
    We recently changed the DateTime Behavior attribute from User Local to DateOnly for static date fields (Date of Birth, Date of Death) so that all users in all time zones see the same date.
    From our research, we understood that, in the database, the time portion of the DateTime fieldwould continue to be 00:00:00.000. Since the attribute change, it is actually converting the time.
    For example: A field with '02/05/2019', saved in EST is displaying properly on the screen for all users in all zones but querying the database (i.e. SQL Report) shows the following in the database:
    2019-02-04 19:00:00.000
    We were expecting 2019-02-05 00:00:00.000
    Dynamics 365 On-premise, 8.2.2.2012
    Has anyone else experienced this?  This can be a huge problem moving forward.
    Andrea Melee
    CFMWS
    Ottawa ON
  • 2.  RE: DateTime field attribute DataOnly adds time to database
    Posted Feb 06, 2019 05:37 AM
    Hi Andrea, this is a known effect of changing the behavior.
    You could probably be helped by using the DateTime Behavior Utility for XrmToolBox to adjust the underlying data.
    https://www.xrmtoolbox.com/plugins/Innofactor.XTB.DateTimeBehaviorUtility/
    I haven't used it in quite some time, but it was created for the sole purpose of handling this type of problems.
    Jonas Rapp
    MVP, Enterprise Architect
    Avanade
    Täby
  • 3.  RE: DateTime field attribute DataOnly adds time to database
    Posted Feb 07, 2019 09:34 AM
    Andrea
    Is you SQL report using the view or the base table? If base table, switch it to the view as it has the mechanisms to properly display the date based on the user settings.
    Rex Kenley Tan, MCP
    Akron OH
  • 4.  RE: DateTime field attribute DataOnly adds time to database
    Posted Feb 07, 2019 01:30 PM
    Thanks Rex for the hint to check views vs tables.  I actually found this as the result.  It seems CRMAF_Filtered is returning the adjusted vaules (which we do not want).
    Here dateinitiated has 'DateOnly' Behaviour, CreatedOn is the OOTB field which has not been changed.
    Select CRMAF_Filterednew_tbl.new_dateinitiated as dateinitiated, CRMAF_Filterednew_tbl.createdon as CreatedOn
    from  CRMAF_Filterednew_tbl
    dateinitiated                               CreatedOn
    2016-07-07 00:00:00.000                2016-07-07 11:52:00.000
    2019-02-04 19:00:00.000                2019-02-05 12:25:30.000
    Select new_tbl.new_dateinitiated as dateinitiated, new_tbl.createdon as CreatedOn
    from new_tbl
    2016-07-07 04:00:00.000                2016-07-07 15:52:00.000
    2019-02-05 00:00:00.000                2019-02-05 17:25:30.000
    Select new_tblBase.new_dateinitiated as dateinitiated, new_tblBase.createdon as CreatedOn
    from new_tblBase
    Is there another way to filter the results for a report if CRMAF_Filtered is returning wrong data?
    Andrea Melee
    CFMWS
    Ottawa ON
  • 5.  RE: DateTime field attribute DataOnly adds time to database
    Posted Feb 07, 2019 02:19 PM
    Andrea
    Off the top of my head, I can think off 2 solutions
    1.) Since CRMAF is partially controlled by the user's time zone setting. Create a "service view" account that has a time zone setting that would return the correct value. Use the "service view" account to impersonate every time this report is loaded.
    2.) Create an inner join that returns the CRMAF columns except datetime and the datetime columns from the tables.
    Rex Kenley Tan, MCP
    Akron OH
  • 6.  RE: DateTime field attribute DataOnly adds time to database
    Posted Feb 08, 2019 10:40 AM
    Thanks Rex.
    What I actually did was add 8hrs to the date fields for the reports that need CMRAF. As the users for these reports are Headquarters based, adding this time will always be accurate now.  We will have to keep this in mind for future enhancements when multiple time zones come into play.  Perhaps an impersonation account may be useful.
    As another note for anyone else noticing this, we also have some reports being generated via SSIS using Kingswaysoft adapter.  Dates were also miscalculated on those as well.  In the adapter, we changed "Output Timezone" from "Adjust to timezone of Connection User" to "UTC(Default)" and the dates now are all matching in CRM and the reports.
    Andrea Melee
    CFMWS
    Ottawa ON
