Trying to Add Labels from a Multi Select Option Set to email templates
  • 1.  Trying to Add Labels from a Multi Select Option Set to email templates
    Posted Oct 19, 2021 09:51 AM
    I'm trying to insert the labels from a multi-select option set into an email template for users to access but I am just getting the number values when it pulls into the template.  I found this article on how to get the labels to display but it looks like this process doesn't work in the new email editor as I can't manually insert dynamic text like I used to be able to with the old editor.
    1 - does anyone know of an easy way to insert the labels of a MSOS without creating a workflow?
    2 - does anyone know of a way to insert dynamic text directly in the email template body in the new editor?
    Eric
    Eric Veneziano
    Sales System Analyst
    Minitab, Inc.
    State College PA
  • 2.  RE: Trying to Add Labels from a Multi Select Option Set to email templates
    Posted 20 days ago
    Eric,
    Did anyone ever respond?  I'm having the same issue trying to insert a multi-select option set into an email template.  I did find one article that showed a /@name inserted at the end of the dynamic text but i can't find a way to edit the dynamic text or add a string with the format of dynamic text and have it actually be dynamic text.
    Thank you,
    Jim Corriveau
    A.W. Chesterton Company
    Groveland MA
