Automatically Populate Email Subject with Regarding Entity Field
  • 1.  Automatically Populate Email Subject with Regarding Entity Field
    Posted 8 days ago
    When creating a new email from the Timeline on a record, we would like the Email Subject to automatically populate with the regarding object's name.  For this situation, I am only working in emails created from an opportunity.  It could be expanded to other entities in the future.  I have checked the relationship and do not see a way to edit the mapping.  Business Rules do not allow to pull a field value from a related record.  A workflow only allows the field to populate after clicking Save.  While that is not the end of the world, I know it will confuse and bother at least some of our end users.
    Will I have to use JavaScript to populate it OnLoad, or does someone have another idea or solution they have used?  Thanks in advance!
    Ben Edgren
    CRM Applications Manager
    Hufcor, Inc
    Janesville WI
  • 2.  RE: Automatically Populate Email Subject with Regarding Entity Field
    Posted 8 days ago
    Your workaround here is to have another workflow that populates a field in the opportunity entity with the name of the lead or contact in question - that way you can easily pull it into the email subject.
  • 3.  RE: Automatically Populate Email Subject with Regarding Entity Field
    Posted 7 days ago
    @Ben Edgren
    If this is a "universal" feature, you can also use a plugin that would automatically fill the subject on create.​
    Rex Kenley Tan, MCSA, MCSD
    Tallmadge OH
  • 4.  RE: Automatically Populate Email Subject with Regarding Entity Field
    Posted 7 days ago
    Edited by Ben Edgren 7 days ago
    Thank you for your suggestions!
    @Donal McCarthy I may not have been clear in my initial post.  What I would like is:
    1. Viewing an Opportunity record
    2. In the Timeline, click the + and then Email
    3. When the email opens, it automatically pulls the Opportunity Name into the Email Subject
    @Rex Kenley Tan, I figure that may be best globally for the system, but I'm just a copy/paste developer.  So we'll probably expand to a plugin when we hire a developer for other work in the future.​​
    Ben Edgren
    Hufcor, Inc
    Janesville WI
