Auto Refresh
  • 1.  Auto Refresh
    Is there a way to auto refresh a page after a certain amount of time? I current have business process that starts from an entity record, steps two moves to an activity record with the regarding set as the original entity, and then when that activity is complete, the business process takes you back to the regarding but does not "visually" move the business process bar to the next stage. In the background, the stage is moved, but you have to refresh the page. I'm look to have the page refresh after the stage is moved in the background or maybe have an alert the doesn't show a "move forward" button until the background process takes place, so you won't have to refresh.
    Tristan Holt
    StoneMor Partners
    Trevose PA
  • 2.  RE: Auto Refresh
    I'm not 100% clear on how you are moving stages - I'm assuming its a workflow or action? Based on this, I do not believe there is any way to refresh the page using server side code or workflow. You could use JavaScript for client side scripting but how will you know when the workflow is run. In my environment, I settled on client side notifications to remind them to refresh the page to update the BPF. This is a great resource to use D365 notifications. https://neilparkhurst.com/2015/11/02/javascript-notifications/
    Maxine Harwood
    Best Practice Software
  • 3.  RE: Auto Refresh
    Hi @Tristan Holt, when you say ​"In the background, the stage is moved", what field is being updated in the background?
    We've started using a workflow to use the Active Stage field from the BPF to update our Pipeline Stage field on the opportunity form so you may want to look into the Active Stage field if you aren't using it.
  • 4.  RE: Auto Refresh
    Tristan
    1.) Is there a way to auto refresh a page after a certain amount of time?
    Yes, but I don't recommend it.
    https://www.w3schools.com/jsref/met_win_settimeout.asp
    2.) I'm look to have the page refresh after the stage is moved in the background
    It might be better to use a progress bar, especially if you don't want the user to do anything else until the background process is done.
    I would display the progress bar to "lock" the screen and initiate an async call that queries the stage. Once I get a response back, that would trigger the page to refresh.
    Rex Kenley Tan, MCP
    Akron OH
  • 5.  RE: Auto Refresh
    Edited by Tristan Holt 11 days ago
    Rex,
    The progress bar would be ideal. How would I set that up?
    Tristan Holt
    StoneMor Partners
    Trevose PA
  • 6.  RE: Auto Refresh
    Open Progress Indicator using Xrm.Utility in Dynamics 365 v9.0
    Inogic remove preview
    A few months back Microsoft has announced the release of Dynamics 365 v9.0 and has come up with many cool features. Where some of them are related to functionality while others are related to UI. Well! The list of newly added features is quite long though not exhaustive.
    View this on Inogic >
    Rex Kenley Tan, MCP
    Akron OH
  • 7.  RE: Auto Refresh
    Rex,
    Is this only for Version 9 and above? If so, is there another solution for version 8.2?
    Tristan Holt
    StoneMor Partners
    Trevose PA
  • 8.  RE: Auto Refresh
    https://github.com/PaulNieuwelaar/alertjs
    Rex Kenley Tan, MCP
    Akron OH
