Business Rules not working after deployment
  • 1.  Business Rules not working after deployment
    Posted Feb 08, 2019 11:20 AM
    ​Business Rules are not working after deployment. I have to deactivate and activate Business rule again to make it work.
    I do not know the reason why this is happening? Anyone in CRM user group faced the same issue.
    regards
    Jeebo Mathews
    Agricorp
  • 2.  RE: Business Rules not working after deployment
    Posted Feb 08, 2019 10:53 PM
    Did you manually create any fields in the production environment, or are you certain they were all created through an imported solution?
    Are you referencing any teams or queues in the business rules?
    I have seen cases where a team or a queue is created manually in the sandbox and also in production. This makes it appear that they right data is in both places, but they actually have distinctly different GUID's. So when you create a workflow or business rule, it will reference the other records (such as a team) using its GUID instead of the actual name, and then when you deploy it, it will not work.
    If that is the case, then you will have to make a copy of your production environment to a new development sandbox. After that, I recommend you use the Data Transporter tool in XRMToolbox to migrate Queues and Teams (in that order) from your Dev, to Staging and Production environments.
    Nelson Johnson
    Solution Architect
    BroadPoint, Inc.
    Bethesda MD
  • 3.  RE: Business Rules not working after deployment
    Posted Feb 11, 2019 11:50 AM
    Also - what kind of deployment was this? What version are you on?
    When we first upgraded to CRM 2016, we had a lot of issues with Business Rules not firing. The fix was related to security role change. Check out the details here: https://readyxrm.blog/2017/05/01/dynamics-crm-business-rules-not-working-issue/
    Kylie Kiser
    Supervisor, CRM System
    Fairfax VA
    www.CRMUG.com/Washington
  • 4.  RE: Business Rules not working after deployment
    Posted Feb 12, 2019 10:44 AM
    Another thing to check is Legacy Form Rendering. I had some strange issues with one of our business rules that was caused by Legacy Rendering. Good luck!
    Greg Enns
    ERP Coordinator
    Technical Prospects
    Kaukauna WI
  • 5.  RE: Business Rules not working after deployment
    I've just experienced this issue.  We have been having some issues (outside of this) and was asked to turn off the legacy form rendering to fix one issue and now my business rules are not working.  I have several fields to hide and show based on the Account Type and now none of them work because of this.  So, check the System Settings to see if it's on or off.
    Good luck!
    Cara McCulloch
    Green Shield Canada
    Windsor ON
