Replacement for On Demand workflow in New Unified Interface.
  • 1.  Replacement for On Demand workflow in New Unified Interface.
    Posted Mar 02, 2020 03:32 PM
    HI,
    what is the replacement for on-Demand workflow in new UI?
    I believe it should be canvas app calling power automate. Anything other than what I said?
    Let me know how others are replacing On-Demand workflow.
    Regards
    Jeebo Mathews
    Agricorp
  • 2.  RE: Replacement for On Demand workflow in New Unified Interface.
    Posted Mar 03, 2020 03:37 AM
    Jeebo,
    The on-demand workflows are still available in the new user interface (UCI) but they are not enabled by default. In the (hopefully far) future Power Automate (fka Flow) will replace the functionality of on-demand workflows.
    To enable the known on-demand workflows, you need to switch on Flow in System Settings:
    Enable Flow in Dynamics 365
    You will find a fly-out menu Flow in each form and grid ribbon bar then and this will contain your on-demand workflows as in legacy web application:
    Flow ribbon bar
    Hauke Jacobsen
    Drägerwerk AG & Co. KGaA
    Lübeck Germany
  • 3.  RE: Replacement for On Demand workflow in New Unified Interface.
    Posted Mar 03, 2020 10:30 AM
    Thanks Hauke Jacobsen for your valuable information.
    Jeebo Mathews
    Agricorp
  • 4.  RE: Replacement for On Demand workflow in New Unified Interface.
    Hello Hauke.  Would there be any other reason I wouldn't see the Flow flyout?  I updated my customizations tab to enable Flow and I'm a system admin so my security rights already include the ability for Flow, however, I still don't see the flyout when I select a record.  I've made sure I have active, on-demand workflows for the entity I'm testing it for, but no luck.  Thanks!!
    Scott Glisson
    CRM Administrator/Business Analyst
    Randall-Reilly, LLC
    Tuscaloosa AL
  • 5.  RE: Replacement for On Demand workflow in New Unified Interface.
    Hi Scott,
    After updating the customization tab to enable Flow. You can logout and login again into CRM to see if you are able to see on-demand workflows for the entity.
    I remember I had similar issue as you are having.
    Jeebo Mathews
    Agricorp
  • 6.  RE: Replacement for On Demand workflow in New Unified Interface.
    Yes!  That was it.  Thank you!
    Scott Glisson
    Director, Enterprise Applications
    205-248-1568 (D)
    Randall-Reilly | 3200 Rice Mine Road NE, Tuscaloosa, AL 35406
    randallreilly.com | facebook.com/randallreilly | twitter.com/randallreilly
  • 7.  RE: Replacement for On Demand workflow in New Unified Interface.
    The Flow equivalent to the On Demand workflow is the 'When a row is selected' trigger; however, this trigger is previous generation and is not solution aware.
    It's also a little flakey. To get it to work properly, don't change the name of the trigger, and add a get record after it to get the record that triggers the flow.
