Currency field formatting inconsistencies in views in Unified Interface
  • 1.  Currency field formatting inconsistencies in views in Unified Interface
    Posted Sep 03, 2019 08:12 AM
    I'm experiencing some inconsistencies with digit grouping and currency codes in currency fields on views in Unified Interface.
    On some views, the currency fields are showing as expected according to the format set:
    However, on other views, the same field is displayed without the digit grouping and currency:
    Both standard currency, base and calculated currency fields are to be affected. Sometimes, If I add a new currency column to an affected view, suddenly the formatting is showing up correctly on all columns.
    When the fields are shown on a form, they show up correctly at all times.
    Has anyone else experiences this? Are there perhaps some discrepancies with settings that are causing this? E.g. System settings vs. personal settings vs. field settings - or is this just a bug?
  • 2.  RE: Currency field formatting inconsistencies in views in Unified Interface
    Posted Sep 10, 2019 06:16 AM
    Did you get anywhere with this? I'm finding that when I have base and local in a view, the formatting is correct. When I include base only, the formatting is lost.
    Pete Axtell
    Winton
  • 3.  RE: Currency field formatting inconsistencies in views in Unified Interface
    Posted Sep 11, 2019 04:22 AM
    @Pete Axtell,
    I reached the same conclusion as you did. You need to have the local currency column in the view for the base currency column to format properly. I don't know if this is by design or a bug. However, it is quite annoying that you have to include an extra column in the​ view when the density in unified interface is already bad as it is.
