Skip empty stages when moving my case forward to the next stage
  • 1.  Skip empty stages when moving my case forward to the next stage
    Posted Mar 09, 2020 02:37 PM
    Hi all,
    In our case management system, we want to skip empty stages when moving my case forward to the next stage. A case record is created along with a business proccess flow (BPF). Each BPF has stages. A stage can have tasks to be complete or canceled. A stage can be empty. How we can do this? We build a plugin to resolve this issue but the active stage is not set to active. Anyone have a solution design. I will appreciate.
    Suppose that we have stages S1 -> S2 -> S3. S2 does not have task; S3 has tasks; I'm in S1 and click Next Stage button; I should go directly to S3
    Arsene Sabas
    Canadian Nuclear Safety Commission
    Ottawa
  • 2.  RE: Skip empty stages when moving my case forward to the next stage
    Posted 30 days ago
    Hi Arsene,
    I believe you can use workflow on this by listening to the business process flow attached to the case entity.
    When you create a workflow, set the business process flow as the primary entity and listen to active stage/status change of it, then you can update and set the stage that you want.
    Hope this gives you an idea.
    Lyrio Amurao
    Tala Dynamics
    North York
  • 3.  RE: Skip empty stages when moving my case forward to the next stage
    Posted 28 days ago
    @Arsene Sabas - You may consider using Branching Logic in the BPFs. For example, you can specify if certain values are in certain fields in S1, then show/hide subsequent stages.
    Here is a link for more information:  ​https://docs.microsoft.com/en-us/dynamics365/customerengagement/on-premises/customize/enhance-business-process-flows-branching
    Aaron Back
    ACE Microtechnology
