Authentication on premises
  • 1.  Authentication on premises
    Posted Apr 02, 2019 11:39 AM
    Hi all, so in our on premises D365 organisation we have windows authentication only, which is now stopping me from using the App for phones, even when using a per device VPN (heavily focussed on security here). We don't want to expose our org to external access but do want to use the mobile app...
    My question is around IFD and switching to Claims Based Authentication. Will that mean we become less secure . Also, what, of any, are the other benefits to Claims over Windows authentition?
    Any advice is welcome
    Robin Marshall
    Dynamics Competency Centre Lead
    Babcock International
  • 2.  RE: Authentication on premises
    Posted Apr 03, 2019 10:47 AM
    Robin,  IFD is a requirement for the mobile App so there is no way round that.
    Are you less secure?  I guess the answer depends on what you mean by less secure. The authentication scheme is no less secure but as you point out you will expose Dynamics to access over the Internet so there will be a risk of someone getting in if they can "guess" a correct username/password combination.
    Claims based authentication for Dynamics on-premises still uses a user's active directory account.
    Feridun Kadir
    Principal Consultant, MVP
    Expert CRM Services Ltd
    Stansted
  • 3.  RE: Authentication on premises
    Posted Apr 04, 2019 08:14 AM
    ​You don't actually need to have CRM exposed to the internet, you just need IFD, which means you can have ADFS and your own DNS all sitting inside your network and access over a VPN.
    Of course these days no one needs to expose CRM via IFD directly to the internet anyway, instead people set up a WAP server in the DMZ, then they can use a host of more secure methods of limiting access.
    Dave Bostock
  • 4.  RE: Authentication on premises
    Posted Apr 04, 2019 08:54 AM
    @Dave Bostock. Good point on setting up IFD and accessing over a VPN.
    Feridun Kadir
    Stansted
  • 5.  RE: Authentication on premises
    Posted Apr 03, 2019 03:36 PM
    Robin,
    I believe you can still configure your SSO provider (eg ADFS) to use Multi-Factor Authentication, so that enabling IFD, while exposing you to the public, doesn't have to mean that you're vulnerable to just a username/password.  I haven't set that up before, but here's a sample link from DUO and their ADFS module:
    https://duo.com/docs/adfs
    Mike Power
    American University
    Washington DC
  • 6.  RE: Authentication on premises
    Posted Apr 04, 2019 09:11 AM
    we have 8.x On-Prem and till last year we used IFD without publishing it to the Internet. Access was only possible via VPN.
    That works in general. But I think that the CRM-app is not really designed to work over a VPN e.g. when you put your iPhone in sleep-mode the VPN gets disconnected (but I think that also depends on your VPN and/or iOS-settings), then the CRM-app would go into offline-mode.
    Even if you then manually reconnect to the VPN you have to manually tap "go online" again in the CRM-app.
    I think there is also a possibilty to activate some kind of "per-App-VPN" that automatically connects to the VPN when a specific app is launched.
    All in all it was very slow and buggy for us.
    We now use IFD with publishing it to the internet and Azure MFA. That works perfectly and the users are very happy.
    Johannes
    Johannes .
  • 7.  RE: Authentication on premises
    Posted Apr 06, 2019 03:09 AM
    Many thanks Johannes, all sounds promising as our new mobile app model is to have per app VPN access only. This may be a second rate user experience by the sounds of it though but to be honest I think our users would still be happy
    Thanks for your suggestions all of you, plenty to work to get on with!
    Robin Marshall
  • 8.  RE: Authentication on premises
    Posted Apr 15, 2019 10:19 AM
    Hi @Johannes ., any chance you can give some more detail about how you set up IFD internally with access only via VPN?​
    Robin Marshall
  • 9.  RE: Authentication on premises
    Posted Apr 16, 2019 02:56 AM
    Hi Robin,
    sorry, I don't have any technical knowledge of the process. In general i think you just activate IFD but do not publish the site in IIS.
    Johannes
    Johannes .
    Albis
