Two optionset dependency
  • 1.  Two optionset dependency
    Posted Nov 12, 2019 01:43 PM
    ​Hi,
    I am trying to filter 2nd option set values based on the 1st option set value selected by the user.
    I am following the below URL example.
    https://www.powerobjects.com/blog/2016/03/15/how-to-use-dependent-lookups-for-dynamics-crm-201320152016/
    but the 2nd optionset values are not filtered out. it shows all the values right now.
    Anyone has any idea why the filter does not happening?
    Regards
    Jeebo Mathews
    Agricorp
  • 2.  RE: Two optionset dependency
    Posted Nov 12, 2019 02:21 PM
    In your post you're talking about optionsets and article demonstrates how to implement dependent lookups.
    Optionsets and lookups are different so please write what exact type of field you plan to make dependent.
    Andrew Butenko
  • 3.  RE: Two optionset dependency
    Posted Nov 12, 2019 02:25 PM
    Sorry its Lookups not option set.​
    Jeebo Mathews
    Agricorp
  • 4.  RE: Two optionset dependency
    Posted Nov 12, 2019 02:28 PM
    Can you please provide a screenshot with configuration of the dependent lookup like it is shown here:
    Andrew Butenko
  • 5.  RE: Two optionset dependency
    Posted Nov 12, 2019 03:29 PM
    Seems like redefining relation mapping between the SubClass and Accounts did the trick.
    which is weird. After doing it lookup started filtering values.
    Thanks Andrew for your reply to my email.
    Jeebo Mathews
    Agricorp
  • 6.  RE: Two optionset dependency
    Posted Nov 12, 2019 03:31 PM
    You are welcome!
    Andrew Butenko
