Not able to restrict views on a sub-grid
  • 1.  Not able to restrict views on a sub-grid
    Posted Feb 10, 2020 11:49 AM
    Hi all,
    We're on D365 Online CE v9 classic interface.  I've created a sub-grid called Featured Partners for users to add accounts to.  I've set the default view to a Featured Partners (a view i've created which in our Dev environment contains 7 accounts).
    When I click on the magnifying glass it displays accounts that aren't in the Featured Partners view...
    ...and when I click on Look Up More Records, the default view is Account Lookup View and I am able to change the view to any one of the other system and personal view in the environment.
    I've had a look in the UI and get the same behaviour.  Am I doing something wrong?  Is this a known issue or should I raise a support ticket with Microsoft?
    Many thanks in advance,
    #Admin​​
    Engineer
  • 2.  RE: Not able to restrict views on a sub-grid
    Posted Feb 10, 2020 11:55 AM
    Mark,
    Behavior you describe is expected because this is how Dynamics CE works for the last decade.
    When you configure and limit the list of available view - it's applied to the grid itself and not to add records behavior.
    If you want to change that behavior you should read this post - https://www.magnetismsolutions.com/blog/paulnieuwelaar/2018/05/17/filter-n-n-add-existing-lookup-dynamics-365-v9-supported-code
    Andrew Butenko
  • 3.  RE: Not able to restrict views on a sub-grid
    Posted Feb 11, 2020 05:33 AM
    Hi @Andrew Butenko, many thanks for the reply and link to the supported code.  I'll pass this onto our developers to see if they can pick this up.​
    Engineer
