Java and Current User Email
  • 1.  Java and Current User Email
    Posted Jun 06, 2019 04:57 PM
    Does anyone know how to use Java to return the current logged in user's email (primary email address from his user record)
    We are needed to pass that parameter in CRM 365 and Resco....Resco I can only pull the login....which is the email.
    Martin Doll
    Ennis-Flint, Inc.
    Thomasville NC
  • 2.  RE: Java and Current User Email
    Posted Jun 10, 2019 09:32 AM
    You should be able to retrieve this from the user's (systemuser) record using a retrieve with the new web API:
    https://docs.microsoft.com/en-us/dynamics365/customer-engagement/developer/clientapi/reference/xrm-webapi/retrieverecord
    And the current user's ID will be available from the new global context: https://docs.microsoft.com/en-us/dynamics365/customer-engagement/developer/clientapi/reference/xrm-utility/getglobalcontext/usersettings
    Hope this helps!
    Aaron Hirshfield
    Sr. CRM Developer
    Foundation Medicine
    Needham MA
  • 3.  RE: Java and Current User Email
    Posted Jun 10, 2019 01:40 PM
    Thanks Aaron.
    I was speaking more on the client side - java....where I have an html button and are passing parameters to a url.
    Martin Doll
    Ennis-Flint, Inc.
    Thomasville NC
  • 4.  RE: Java and Current User Email
    Posted Jun 10, 2019 02:31 PM
    Right, this is all client side code. I assumed you were talking about writing a web resource inside CRM? Are you imbedding some external page on your CRM form?
    If it's within CRM, you make a new javascript web resource with a function along the lines of:
    Xrm.WebApi.retrieveRecord("systemuser", Xrm.Utility.getGlobalContext().userSettings.userId, "?$select=emailaddress").then(
    function success(result) {
    // Call your URL here and pass result.emailaddress.
    function (error) {
    console.log(error.message);
    // handle error conditions
    The links I posted have more detailed information.
    Aaron Hirshfield
    Sr. CRM Developer
    Foundation Medicine
    Needham MA
