Hi Rod,
For Microsoft created fields, entities, web resources, etc. the schema name won't have a prefix or it'll be msdyn_ (e.g. industrycode, name). Anything that was built out in the default solution would have the prefix of new_. You could try and search out anything that has that prefix. Plugins should be able to be identified as non-Microsoft. The Microsoft ones would start with Microsoft or ActivityFeed.
This might not be all encompassing but should get you moving towards your goal.
Scott Florance
Sent: Dec 11, 2020 03:55 PM
Subject: Finding past changes to the Default Solution
For our new environment, we will definitely be applying a change-control-process. (Lesson Learned!)
However, for our current CRM 2016 on premise environment, I would like to find all customizations that consultants have made over the past years within the default solution.
Is there an easy way to do this?
Rod Carlson
Database Administrator
Chicago
