Timeline in the new UI
  • 1.  Timeline in the new UI
    I would like to get rid of the big text that says "Timeline".  Is this possible to hide this? We use only the notes section and dont want to display this.  thanks!
  • 2.  RE: Timeline in the new UI
    Hi @Laura Mortick, doesn't look like it is possible.  I change all the properties to Notes and still it says Timeline so you may be stuck with this.
    Sorry!
    Engineer
  • 3.  RE: Timeline in the new UI
    Thanks @Mark Aston - we played around with it the same way and could not figure anything out either!  Appreciate your note!​
  • 4.  RE: Timeline in the new UI
    Under the Unified Interface Properties for the Tab you cannot remove the name it but you could change the name. Make it Notes or Enter your notes here.
    You would need to do this on each form.
    Take a look at this blog for instruction on how to get to the Unified Interface Properties
    Jeff Botts
    Sempra Global
    San Diego CA
  • 5.  RE: Timeline in the new UI
    Hi @Jeff Botts!
    We already tried that and have changed it, but it does not change the word "Timeline" on the form. Were you able to get it to change on your forms?​
  • 6.  RE: Timeline in the new UI
    Sorry I see that is not a Label but the Name.
    Jeff Botts
    Sempra Global
    San Diego CA
