status code value for Option set
  • 1.  status code value for Option set
    Posted 8 days ago
    Dear All,
    Writing this , thinking somebody else might have faced a similar situation.
    We upgraded to version 9 recently , post the upgrade we found for the Appointment entity the statuscode option field shows only two values under UCI/UUI interface . imageOn the web it shows as below
    i checked the form and somehow it seems that we have the status field locked out for Open option set
    status
    When i click on the status to check for close or any other option it does not change .. Anyone else noticing the same behavior ? to me it seems to be a possible MS bug.
    Bhartendu Pandey
    Willis Towers Watson
  • 2.  RE: status code value for Option set
    Posted 8 days ago
    I am noticing the same behavior.
  • 3.  RE: status code value for Option set
    Posted 8 days ago
    Hello @Aaron Back, MCSE​,
    Thank you . I will just pursue this with Microsoft and check with them if they are aware about this Bug.
    Bhartendu Pandey
  • 4.  RE: status code value for Option set
    Posted 7 days ago
    I also see the exact same behavior.
    Nageena Todi
    Pactiv LLC
    Lake Forest IL
  • 5.  RE: status code value for Option set
    Posted 18 hours ago
    Hello @Nageena Todi,
    Thank you for your reply . I have created a support request with Microsoft on this issue.
    Will keep all updated with the progress on the same.​
    Bhartendu Pandey
