Power apps portal - Employee Service Type portal to have Custom Login Page
  • 1.  Power apps portal - Employee Service Type portal to have Custom Login Page
    Edited by Jimmy mcad 13 days ago
    Dear Experts,
    I have a requirement where I need to use a custom login page in employee service type portal (Latest Power apps portal I am using).
    Customer service type portal does have a custom login page feature and we need the same in employee service portal?
    Is there a direct/indirect way, I can enable this in customer service portal. I know one is to import them manually, and there will be some settings required in the setting area too?  If anyone can suggest
    Kind regards,
    Jimmy mcad
  • 2.  RE: Power apps portal - Employee Service Type portal to have Custom Login Page
    Posted yesterday
    Hi Jimmy,
    The Employee Self-Service portal uses Azure AD for login. I believe Azure AD does have some configurability around the login page - that where I'd recommend you check.
    I'm curious - what kind of customization are you looking to do?
    Nicholas Hayduk
    Regina SK
  • 3.  RE: Power apps portal - Employee Service Type portal to have Custom Login Page
    Posted 11 hours ago
    Thanks Nicholas for replying back. I need a login page exactly what we have in customer type portal, a portal user can register through it, and that's it.
    Do you recommend an approach? Kind regards,
    Jimmy mcad
    William Russell Ltd
