Power Automate List records filter
  • 1.  Power Automate List records filter
    Posted Jul 03, 2020 06:51 PM
    I am having trouble with the List Records Filter Query.
    When I enter:
    Or adding the single quotes:
    This is the error:
    The WO Number is the GUID.  I change to the text value output in Work Order Number as below:
    This is the error:
    I try it with the single quotes:
    and I am back to the original error:
    The field in question is named msdyn_workorder and the value in it is WO-000341344
    How should the Filter Query be set to find this record?
    Thank you in advance,
    Paul Richards
    BlueCrest Inc
    Danbury
  • 2.  RE: Power Automate List records filter
    Posted 28 days ago
    Hi Paul - a good help would be to use FetchXML Builder for XrmToolBox to construct the query, and then have it compose the List Records parameters for you.
    See a sample of this feature: https://fetchxmlbuilder.com/features/#render-flow
    Jonas
    Jonas Rapp
    MVP
    Sweden
  • 3.  RE: Power Automate List records filter
    Posted 27 days ago
    I 2nd using the FetchXMLBuilder from XrmToolBox, in this scenario I'd hazard a guess that the msdyn_workorder field is a lookup, in the fetchxml it'll probably require a link entity to the entity in question, or you could use the odata filter attributes of the Power Automate List Records component which should then allow _msdyn_workorder_value eq 'xxxxx' (or something similar, been a while since I used the odata method)
    Good luck
    Michael Wink
    Willis Towers Watson
    Reigate
  • 4.  RE: Power Automate List records filter
    Posted 27 days ago
    Hi Paul,
    I agree with both of the above responses; FetchXML certainly works but is a bit clunky for such a basic filter. The filters do all work off of odata values, so it's always helpful to run a test flow and review the output values to see how fields are referenced when in doubt.
    However, if you're listing records for a specific GUID, then I'd recommend using the 'Get a record' action. This asks for the entity and GUID as the input, and then the results are not in an array, either, so dynamic content afterwards is much simpler.
    Chad Althaus
    Bray International, Inc.
    Houston TX
  • 5.  RE: Power Automate List records filter
    Posted 27 days ago
    Just to clarify: I wasn't suggesting to use a FetchXML query for this scenario - but to use the tool FetchXML Builder to get the exact filter parameters for the List Records action :)
    Jonas Rapp
    MVP
    Sweden
  • 6.  RE: Power Automate List records filter
    Posted 27 days ago
    Shows how many ways there are to achieve the same result with D365, love it.
    Michael Wink
    Reigate
  • 7.  RE: Power Automate List records filter
    Posted 27 days ago
    Yes, that is what the issue was.  It is a lookup.  I did try adding _value on it and received the same issue.
    In the end, this got the job done:
    I do appreciate everyone's comments on this!!
    Paul Richards
    BlueCrest Inc
    Danbury
  • 8.  RE: Power Automate List records filter
    Posted 25 days ago
    I 2nd using the MyCareerBuilder from Toolbox, in this scenario I'd hazard a guess that the dynamo_work order field is a lookup, in the fetcher it'll probably require a link entity to the entity in question, or you could use the data.
    junaid khan
    it
    lahore
