Export login history for all active users
  • 1.  Export login history for all active users
    Posted Oct 01, 2019 02:52 PM
    The Dynamics 365 team here is trying to find a way to export the login history for all active users in the production environment YTD without the need for programming. If anyone knows of a solution, feedback is appreciated.
    Anthony Parks
    Comfort Systems USA
    Indianapolis IN
  • 2.  RE: Export login history for all active users
    Posted Oct 02, 2019 05:01 AM
    Hi @Anthony Parks, we use the User Audit Viewer​​ plugin in XRM ToolBox to monitor usage.  It allows you to query the login history for each user as well as export a report to Excel for users that haven't logged in within a certain period.  Only annoying thing about the reports are that they don't include users that have never logged in so you have to manually go through each users login history to see if it is blank.
    Engineer
  • 3.  RE: Export login history for all active users
    Posted Oct 02, 2019 08:46 AM
    @Mark Aston
    The XRM ToolBox plug-in can't be done in bulk, correct? Unless I am doing it wrong -- always possible -- you have to look at and export each user individually, correct?​
    Michael Rushton
    StoneMor Partners
    Trevose PA
  • 4.  RE: Export login history for all active users
    Posted Oct 02, 2019 09:06 AM
    Hi @Michael Rushton, you are correct, you can only query individual users as well as export that users' login history.
    Engineer
  • 5.  RE: Export login history for all active users
    Posted Oct 02, 2019 11:20 AM
    Is there anything that can be used to export all enabled users login history for a specified period of time in bulk ?
    Anthony Parks
    Comfort Systems USA
    Indianapolis IN
  • 6.  RE: Export login history for all active users
    Posted Oct 02, 2019 12:30 PM
    We are very much needing this too.
    Kristina Bjerknes
    REDW
  • 7.  RE: Export login history for all active users
    Posted Oct 02, 2019 03:14 PM
    The XrmToolbox has a tool that extracts the D365 Users with last log-in called User Audit Viewer.
    Hugh Konigsmark
    Global CRM/CPQ Director
    Bray International, Inc.
    Houston TX
  • 8.  RE: Export login history for all active users
    Posted Oct 03, 2019 02:09 AM
    You also need to have enabled 'Audit User Access' in System Settings.
    In case this is disabled, no logs can be retrieved.
    Alexandros Miaris
    CRM Consultant
    Dixons Carphone
    Peristeri
  • 9.  RE: Export login history for all active users
    Posted Oct 03, 2019 06:44 AM
    Edited by Jamie Parbery Oct 03, 2019 06:44 AM
    Just to add to this, at some point a while back, Read Auditing came out which started pushing stuff to the Security and Compliance Centre. One of the things it should be collecting is 'Signed in or Out'.
    https://docs.microsoft.com/en-us/dynamics365/customerengagement/on-premises/admin/enable-use-comprehensive-auditing ​
    I was testing this at the time and while I was able to export some stuff, a lot of the switches didnt really work and the export was a mess with a lot of the useful stuff unfilterable.
    I have no idea whether this has changed at all in the months since but its possibly worth looking at to see what can be done with it now.
    Jamie
    Jamie Parbery
    Kier Ltd
  • 10.  RE: Export login history for all active users
    Posted Oct 03, 2019 07:20 AM
    Hi @Jamie Parbery, I assume you are an Office 365 Global Admin to access the Security and Compliance Centre?  As a Dynamics System Admin I don't have permissions to access the Security and Compliance Centre.  One of our O365 Global Admins did show me what it looked like and as you say not all of it worked and the export was a mess.
    Engineer
  • 11.  RE: Export login history for all active users
    Posted Oct 03, 2019 07:30 AM
    ​It's hard to tell exactly what permissions got me into it as we're using a PIM thing and I have to request Global Admin to get into the O365 admin just for licensing stuff. I have little idea where the other O365 admin roles get you to be honest as we've not used them.
    Security and Compliance isn't our area either so I was surprised to be able to get into it without fighting the security guys for specific Privs.
    It feels like eventually all audits across power platfom stuff will end up in this area but the requirement for O365 admin rights outside of the D365 security roles brings its own confusion. This stuff is worth keeping an eye on the for improvements but we didn't find it to solve this requirement and ultimately resorted to XRMToolbox and/or giving up like everyone else.
    Jamie Parbery
    Kier Ltd
  • 12.  RE: Export login history for all active users
    Posted Oct 03, 2019 07:31 AM
    You can hit the audit logs with Power BI. I've seen it done. Unfortunately, our audit logs are too big and I've had trouble getting any reports built. It's worth a shot to see if you can get it to work. If you can hit them, I would think you can pull out the specific user access records.
    Julie Reynolds
    Brotherhood Mutual Insurance
    Fort Wayne IN
  • 13.  RE: Export login history for all active users
    Posted Oct 03, 2019 07:39 AM
    As I was posting that, I realized that I can hit our test site which has all the logs except the current quarter deleted. It's amazing how fast it loaded as we only have 3 days of audit logs and I'm the only one who has done anything on that site! I'm actually excited that I can actually see something. Now to figure out how to be able to work with our production data.....
    Julie Reynolds
    Fort Wayne IN
  • 14.  RE: Export login history for all active users
    Posted Oct 04, 2019 11:06 AM
    Have you looked at PowerGeoLog from PowerObjects?
    https://www.powerobjects.com/powerpacks/powergeolog/
    Full Disclosure: I work for PowerObjects, but I'm not in sales. :-)
    While its normal function is to alert you if someone tries to login from an unknown location, the basic part is that it tracks the users logins. I've implemented it for a similar request to track who was logging in. We then did a rollup on the related user record to show how many logins they had, which allowed the administrator to see who was NOT logging in (rollup field = 0) so they could disable and re-use the license.
    Good luck!
    Chris Harrington
    Solutions Architect
    PowerObjects, an HCL Company
  • 15.  RE: Export login history for all active users
    Posted Oct 07, 2019 02:52 AM
    We are in the progress of doing a user access audit. We found the XRM toolbox User Audit Viewer plugin to not meet our needs. We have over 650 users and just needed to know who had logged in within the last month or so.
    I ended up writing the following FetchXML and running it in the FetchXML Tester in XRM Toolbox.
    Due to the volume of data we have (with 650+ users and the multiple login activities which occur each day) we could only run it for just over a month without it timing out.
    Hope this helps.
    <fetch version="1.0" output-format="xml-platform" mapping="logical" distinct="true" aggregate="true" no-lock="false" >
        <entity name="audit" >
            <attribute name="createdon" alias="lastlogon" aggregate="max" />
            <attribute name="action" groupby="true" alias="actionid" />
            <attribute name="userid" groupby="true" alias="name" />
            <filter type="and" >
                <condition attribute="action" operator="eq" value="64" />
                <condition attribute="createdon" operator="on-or-after" value="2019-09-01" />
            </filter>
            <link-entity name="systemuser" from="systemuserid" to="objectid" link-type="outer" alias="SystemUser" >
                <attribute name="fullname" groupby="true" alias="fullname" />
                <attribute name="isdisabled" groupby="true" alias="isdisable" />
                    <condition attribute="isdisabled" operator="eq" value="0" />
                </filter>
            </link-entity>
        </entity>
    </fetch>
    Sharon Fish
    Beyond Bank Australia
    Adelaide
  • 16.  RE: Export login history for all active users
    Posted Oct 24, 2019 06:51 PM
    Hi Sharon! What do you do with the response data from the FetchXML tester?
    Rosemarie Cordell
    Business Analyst
    NEWBERG OR
  • 17.  RE: Export login history for all active users
    Posted Oct 27, 2019 04:19 PM
    Hi Rosemarie,
    We copy this out into Excel and then filter for what we need. We then put formulas around it to extract just the user name and the date.
    This is used for some of our auditing activities.
    Sharon Fish
    Adelaide
  • 18.  RE: Export login history for all active users
    Posted Feb 01, 2021 09:41 AM
    Edited by Scott Jackson Feb 01, 2021 09:42 AM
    For the benefit of people reading this thread I found an easy way to convert the XML output from the FetchXML Tester tool.
    I ran FetchXML query above, then from the output window, highlight all of the text, open up notepad, and save the file as output.xml,  then open up that file in Excel, and it will offer to convert it for you and you get a nice clean Excel table with the columns all separated with no work
    Scott Jackson
    Business Systems Manager
    Montagu Private Equity
  • 19.  RE: Export login history for all active users
    Posted Oct 25, 2019 03:53 AM
    Hi Sharon,
    Great code, thanks.
    So in our organisation we have a set of people using CRM for opportunity management (around 600 licenses, active users...??). This would be great to see who is not "doing their job" and to clear out licenses. However we also have another 1000 members of staff who are using PSA to log their time and expenses. They are also coming up in the logs. And bloating incredibly that I can only pull back a handful of days before I hit the limit.
    I wonder if there is an easy way to distinguish between people interacting just with the Time and Expense modules and those using CRM?
    Justin.
    Justin Jones
    Control Risks
  • 20.  RE: Export login history for all active users
