How to Add a Personal or System View to the Solutions Entity
  • 1.  How to Add a Personal or System View to the Solutions Entity
    How can I add a personal or system view to the Solutions Entity?  I've tried in classic Solutions pages and in the PowerApps page and cannot add a view.
    Any help is appreciated, thank you.
    Jim Corriveau
    A.W. Chesterton Company
    Groveland MA
  • 2.  RE: How to Add a Personal or System View to the Solutions Entity
    Morning Jim,
    The nature of Personal Views is that you share them with other Users. If you wanted to turn it into a System View you need the xml. You can use the XRM Toolbox to convert Personal Views to System ones.
    Once they are a System View you should be able to add this into your Solution. From your Solution add the Entity, then under Views you will see the System View you have created. Select that then it is ready to be ported across.
    I hope that helps.
    Jess
    Jessica Howes
    Microsoft Dynamics Specialist
    Opus
    Reigate
  • 3.  RE: How to Add a Personal or System View to the Solutions Entity
    As well as what @Jessica Howes says, you also need to ensure that the view is enabled in the modal app you are using.
    https://docs.microsoft.com/en-us/powerapps/maker/model-driven-apps/create-edit-views-app-designer#work-with-views-in-app-designer
  • 4.  RE: How to Add a Personal or System View to the Solutions Entity
    Hi Jim,
    they did not read the question...
    Bad news, this is not possible.
    Marc
    Marc Lübberstedt
    SYCOR GmbH
    Göttingen
  • 5.  RE: How to Add a Personal or System View to the Solutions Entity
    oooh you think @Jim Corriveau meant a View within the Solutions entity? My apologies Jim if that was what you meant!​​
    Jessica Howes
    Opus
    Reigate
  • 6.  RE: How to Add a Personal or System View to the Solutions Entity
    Hi Jim,
    For clarity, do you want to add a system view to the solution entity or a system view to an unmanaged solution, e.g. add an account system view?
    What Marc says is true, if you are wanting to extend the solution entity itself.
    Garry
    Garry Watson
    Watson PM Ltd
  • 7.  RE: How to Add a Personal or System View to the Solutions Entity
    Thank you for your replies.
    Jim Corriveau
    Groveland MA
