Perform a bound action not visible
  • 1.  Perform a bound action not visible
    Posted Dec 16, 2019 04:21 PM
    Hi All,
    While creating power automate to call custom action i do not see the "Perform a bound action" in the Actions list.
    anybody knows why i cannot see in the list?
    Regards
    Jeebo Mathews
    Agricorp
  • 2.  RE: Perform a bound action not visible
    Posted Dec 16, 2019 04:27 PM
    In order to use "Perform a bound/unbound action" actions you should use CDS(Current Environment) adapter. Check following post - https://saralagerquist.com/2019/12/15/cds-vs-cds-what-connector-should-i-use-in-power-automate/
    Andrew Butenko
  • 3.  RE: Perform a bound action not visible
    Posted Dec 17, 2019 10:05 AM
    Hi Andrew,
    I do not see the CDS(Current Environment) adapter in the current list. Do i have install something to show in the list. I am using trial crm for dev purpose.
    Let me know how to get the CDS(Current Environment) adapter?
    Jeebo Mathews
    Agricorp
  • 4.  RE: Perform a bound action not visible
    Posted Dec 17, 2019 10:19 AM
    @Jeebo Mathews - You can only choose the "CDS (Current Environment)" if you create a Flow from a Solution. In the maker site (https://make.powerapps.com), go to Solutions, create a new solution, then choose the "New" option at the top, then select "flow". This will launch Power Automate. Search for "common data service" and choose the one with "Current Environment". ​
    Aaron Back
    ACE Microtechnology
  • 5.  RE: Perform a bound action not visible
    Posted Dec 18, 2019 09:20 AM
    ​Thanks Aaron and Andrew I could see the CDS( Current Environment) now once I select the solution.
    Jeebo Mathews
    Agricorp
  • 6.  RE: Perform a bound action not visible
    Posted Dec 18, 2019 03:38 PM
    I have issue when i run the model driven app within solution i do not see the my power automate in the flow drop done.
    both the power automate and model driven app are within the same solution.
    Regards
    Jeebo Mathews
    Agricorp
  • 7.  RE: Perform a bound action not visible
    Posted Dec 18, 2019 04:23 PM
    Hi All,
    I want to clarify i am trying to run on demand flow which is present in my solution but when i try to run the model driven app i do  not see the flow in on demand flow list menu.
    Not sure what i am doing wrong here?
    regards
    Jeebo Mathews
    Agricorp
