Entity Number
  • 1.  Entity Number
    Posted 18 days ago
    ​How do i find a list of the OOB entity numbers? Also, how do i know the number for custom entities? Trying to make sense out of the new Admin center reports! Thank you! Laura
  • 2.  RE: Entity Number
    Posted 18 days ago
    ​I did find this, but i was hoping to get a list of all of our entities, rather than have to check one by one... Thanks! Laura
    How to Find the Object Type Code for Any Entity - PowerObjects
    Microsoft Dynamics 365 | PowerObjects remove preview
    Each entity in the system will have an Object type code. For simplicity of understanding, think of it as a numbering system for all the entities, regardless if they are out of the box or custom. As a CRM Expert, you might encounter a situation where you will need to identify the Object Type code for an entity.
    View this on Microsoft Dynamics 365 | PowerObjects >
  • 3.  RE: Entity Number
    Posted 18 days ago
    You can use XrmToolbox and Metadata Browser plugin of it to get that data.
    Andrew Butenko
  • 4.  RE: Entity Number
    ​That worked perfectly - thank you! :)
  • 5.  RE: Entity Number
    You also could query the SQL database:
    SELECT distinct [Name],
    [ObjectTypeCode]
    FROM [yourCRMdatabase].MetadataSchema.Entity order by Name
    Allison Briden
    Energy Trust of Oregon
    Portland OR
