Automatically adding text to description box
  • 1.  Automatically adding text to description box
    Posted Mar 03, 2020 11:33 AM
    Hi All, Hopefully someone can help with this!
    I have a Case form and a requirement is to put a Case Category on each case (no problem there) but if the inputter selects a certain Case Category I want the Free Text Description to be populated with some standard text.
    I have setup an on demand process that triggers when the Record Fields Change.
    Then it checks if the Case Category equals a certain Value and if True add text to the Description box.
    I can't get it to Update the description box - Is it even possible?
    Martin Whelan
    CRM Support Analyst
  • 2.  RE: Automatically adding text to description box
    Posted Mar 03, 2020 04:17 PM
    this sounds like it should work - have you checked the process session after testing to see where it goes wrong?  Is the process succeeding and just not giving the desired result or is it failing?
  • 3.  RE: Automatically adding text to description box
    Posted Mar 04, 2020 03:50 AM
    Hi all,
    Yes indeed a business rule on the form worked perfect.  Many thanks for replying!
    Martin Whelan
    CRM Support Analyst
    Health Business Services HBS
    Thomastown
  • 4.  RE: Automatically adding text to description box
    Posted Mar 04, 2020 01:06 AM
    When you said "add text to the description box", did you mean you used Update step?
    Can you share a screenshot?
    Based on your description, I feel like it can be done through Business Rules.
    Cristall Amurao
    Tala Dynamics
  • 5.  RE: Automatically adding text to description box
    Posted Mar 05, 2020 07:07 AM
    Yes that worked perfect...Do you know if it is possible in the Value field to get 3 lines of text to appear instead of a single line of text.  Such as
    Name:
    Reference:
    i.e. can each line separated by a [CR]. ?
    Martin Whelan
    CRM Support Analyst
    Thomastown
  • 6.  RE: Automatically adding text to description box
    Posted Mar 05, 2020 08:01 AM
    Hi Martin,
    You can play around Multiple LInes of Text type. I believe you can make that work with a custom JavaScript or workflow. If you choose to use a workflow, you will see the changes after saving the record. Business Rules are like JavaScript so validation happens on the client-side.
    Cristall Amurao
    Tala Dynamics
    North York
