Hey Nirav,
Thanks for the Response. I assume you are setting up Data Flows to move data from synapse to sql database. In our case we need to replicate more than 300 tables in which few of them will have more than half a million upserts everyday, Can we achieve this with SSIS? currently we are thinking to setup synapse pipelines to achieve this, so looking for best ways to move forward.
Vikas Gangishetti
CAPFinancial Partners, LLC
Raleigh NC
Sent: Mar 15, 2022 08:24 AM
Subject: Data Export Service (DES) Alternatives
We are also using Dynamics Online and configured Azure Synapse to dump Dynamics data to synapse data lake and then using SSIS bring data to On-premise DB. Which is working great so far. In the past there was some differences on how many entity available through synapse and such ...but slowly Microsoft is bringing more and more entity available. Still tables like StringMap and such metadata is not available, but using WebAPI, it is available. We were able to replace most on-premise PowerBI-integration with on-premise to cloud successfully. Initially, when you configure Synapse, there is window of time period to let everything sync, but later on it is smooth ride. Also there is no troubleshooting ways for synapse links, so if you wants to Resync then basically, unlink and relink synapse.
Configuring Synapse Link is very plug and play model....usually Admin with all Azure Tenant Global Administrator rights can configure most part.
Bringing your Dataverse data to Azure Synapse – Allan De Castro's Power Platform Notebook
Create an Azure Synapse Link for Dataverse with Azure Data Lake - Power Apps | Microsoft Docs
Create an Azure Synapse Link for Dataverse with your Azure Synapse Workspace - Power Apps | Microsoft Docs
Nirav Patel
Software Engineer
Spraying Systems Co.
Wheaton IL
Sent: Mar 15, 2022 01:50 AM
We are looking at this ourselves. We are using Dynamics online. We plan to move to Azure Synapse Link for Dataverse. We are currently looking at whether we use Azure Synapse Link to export data from Dataverse to Azure Synapse Analytics or Dataverse to Azure Data Lake Storage Gen2 or both.
We originally had a need for SQL DB which allowed us to export our data to on-premise data warehouse but this change has highlighted that these older on-premise technologies have no roadmap. So have decided to embrace the cloud technologies and will be moving our data warehouse and lake to the cloud.
If you haven't found it already here is Microsoft's document on this https://docs.microsoft.com/en-us/powerapps/maker/data-platform/export-to-data-lake.
Mark Westerman
Charles Sturt University
Thurgoona
Sent: Mar 14, 2022 05:07 PM
We are looking for peers that currently use Microsoft Dynamics Customer Experience (CE) (aka Dynamics CRM) and its "Data Export Service" (DES) functionality. DES is used to create a near-real-time replica database (ODS) which we use for reporting. DES is being deprecated in November 2022, and we are trying multiple POCs to determine a best replacement path.
We would appreciate any thoughts others have on their approach.
Lauren Palsgrove
