Refresh Test and DEV sandboxes With a Production Instannce full copy
  • 1.  Refresh Test and DEV sandboxes With a Production Instannce full copy
    Posted Sep 25, 2019 02:51 AM
    It may seem a trivial question, but I want anyway propose to our community
    why do we make a full copy of the production Instance to the Test and DEV Sandboxes?
    what are the benefit and the Impacts of to do it?
    thanks in advance
    giovanni manunta
    Georg Fischer
    cernusco sul naviglio
  • 2.  RE: Refresh Test and DEV sandboxes With a Production Instannce full copy
    Posted Sep 25, 2019 03:18 AM
    Hello Giovanni,
    The full copy is good to have in order to do all testing with new developments like as we sere in the production instance.
    Though we should consider any GDPR issues with the full copy, since if yo are located in the EU, no real data are permitted in non-production instances.
    Alexandros Miaris
    CRM Consultant
    Dixons Carphone
    Peristeri
  • 3.  RE: Refresh Test and DEV sandboxes With a Production Instannce full copy
    Posted Sep 25, 2019 04:10 AM
    Thanks for you answer Alexandros,
    What are the GDPR Impacts of this kind of Refresh (TST to PRD) ?
  • 4.  RE: Refresh Test and DEV sandboxes With a Production Instannce full copy
    Posted Sep 25, 2019 04:16 AM
    On TST and DEV environments no real data should exist, or at least no contact data of any kind.
    In case of audit, you will be asked for deleting any contact and/or name details.
    Alexandros Miaris
    CRM Consultant
    Dixons Carphone
    Peristeri
  • 5.  RE: Refresh Test and DEV sandboxes With a Production Instannce full copy
    Posted Sep 25, 2019 04:24 AM
    Following questions
    1)     And what about emails in contacts/accounts ?
    2)     Which are the sensitive data ? Is a possible solution change the sensitive data using other data (example xyz@zxy.nl) ?
    3)     are there some best practices to follow?
    Giovanni Manunta
    Application Owner MS Dynamics 365 CE
    Mobile: +39 338 6031850
    giovanni.manunta@georgfischer.com
    Cernusco sul Naviglio –  Milan – Italy
    Georg Fischer Piping Systems Italy
    Via Sondrio 1 , Cenusco sul Naviglio, 20063, Milan, Italy
    www.gfps.com
    Signatur_Banner_Email_Communication_Teaser_CRM_415x140px_72dpi
  • 6.  RE: Refresh Test and DEV sandboxes With a Production Instannce full copy
    Posted Sep 25, 2019 04:37 AM
    Edited by Alexandros Miaris Sep 25, 2019 04:38 AM
    Emails should not be copied, though it depends on how strict your GDPR model is.
    You can follow up with GDPR compliance to check as type of sensitive data.
    Also, best practices are different between industries. You need to identify your company type and proceed with thorough check regarding GDPR industry best practices.
    Alexandros Miaris
    CRM Consultant
    Dixons Carphone
    Peristeri
  • 7.  RE: Refresh Test and DEV sandboxes With a Production Instannce full copy
    Posted Sep 25, 2019 04:45 AM
    On GDPR side now I know it so thank you so much for this usefull explanation
    what about other the benefit & other Impacts of a full copy from PRD to Sandboxes ?
  • 8.  RE: Refresh Test and DEV sandboxes With a Production Instannce full copy
    Posted Sep 25, 2019 09:08 AM
    Main benefit of Product copy to Test and Dev is for easy testing and easy for troubleshooting production issues. As you have same data from production, you can easily reproduce issues in TEST & Dev instances.
    For Emails or any other sensitive data, once production copy is moved to Test & Dev you can mask this information using scrible or any other integration tools.  For example, replace all emails to contoco.com emails etc.
    Mahadeo Matre
    CRM Solution Architect
    Promega
    Madison WI
  • 9.  RE: Refresh Test and DEV sandboxes With a Production Instannce full copy
    Posted Sep 25, 2019 09:57 AM
    Thank you Mahadeo,
    So what happen to the Click dimension Data when I make a full copy from  Production instance to Test Sandboxes ?
    What are the Click Dimension best practices to follow when you make a full copy of the production to Test sandbox ?
    Giovanni Manunta
    www.gfps.com
  • 10.  RE: Refresh Test and DEV sandboxes With a Production Instannce full copy
    Posted Sep 25, 2019 10:49 AM
    If you have different solution / account key for click dimension, then click dimension data will not work. Web content, forms, Surveys, landing pages mostly wont work.
    Here are some helpful links from Click Dimension for data move
    Moving Customizations from Dev to Test to Production when ClickDimensions is Installed
    https://support.clickdimensions.com/hc/en-us/articles/115001161433
    Considerations when Performing a Database Restore or Sandbox Copy/Reset for a CRM System Integrated with ClickDimensions
    https://support.clickdimensions.com/hc/en-us/articles/115001162813
    Migration and Upgrade Scenarios for ClickDimensions
    https://support.clickdimensions.com/hc/en-us/articles/115001166734-Migration-and-Upgrade-Scenarios-for-ClickDimensions
    Mahadeo Matre
    Promega
    Madison WI
  • 11.  RE: Refresh Test and DEV sandboxes With a Production Instannce full copy
    Posted Oct 01, 2019 09:46 AM
    Giovanni
    SAP & Salesforce have these features available to their developers. The most fundamental benefit is that they can test and validate their code against real world data instead of "made up" data. A lot of companies have the requirement that all their code be tested against the "current state of the business". This especially in situations where a data change is required which the only "undo" is a full db restore. You don't really want to be in a situation where you find a bug in your code while running it in production. According to Delphix, NASA applies this practice.
    https://www.slideshare.net/MurtazaAbdulRazzaq/bestpracticessoftwarechangemgmt
    https://www.delphix.com/blog/application-development/delphix-automic-rewriting-rules-of-sap-refresh
    I am pretty sure that since SAP is a German company, they are in compliance with any EU regulations with regard to this subject.
    Tallmadge OH
