Powerapps - Merge Records from Different Data Sources with ForAll and Patch
  • 1.  Powerapps - Merge Records from Different Data Sources with ForAll and Patch
    Posted May 05, 2021 11:34 AM
    Is it possible to merge records from different data sources using ForAll and Patch?
    Imagine you have a collection of three (3) records created using Data Source A (CollectDataSourceA). Using "ForAll", I want to loop through each record in CollectDataSourceA(ThisRecord) and use fields from it to build objects for Data Source B (DataSourceB).
    ForAll(
      CollectDataSourceA,
      Patch(
        DataSourceB,
        ThisRecord,
        {'Data Source B Field': ThisRecord.Name}
    App Checker keeps giving an error like the following:
    The column specified is not accessible in this context.
    I really need to use the values from the CollectDataSourceA ThisRecord to build Patch records for DataSourceB. Are there any strategies to circumvent this? Any suggestions would be greatly appreciated.
    Rodrick Hales
    Software Consultant
