Whole Number field with format Language
  • 1.  Whole Number field with format Language
    I have created a custom field of type Whole Number with format Language. I have set this field has business required:
    This format offer the possibility to choose a language the list of language available for the organisation. And is apparently set by default on the organisation base language.
    I said "Apparently", because even if the field seems to be filled, it is not and when I save the form it tells me that the field is empty. I have to manually select English even if it is already displayed.
    For your information, I am on Unified Interface.
    Have you already used this format and experienced the same issue? If so, is there a way to bypass it ?
    Best Regards,
    Laurent Maneville
    Nmédia
    Drummondville QC
  • 2.  RE: Whole Number field with format Language
    Hey Laurent this appears to be a bug related to the UCI. If you view it in the Classic UI the field truly is null. Unfortunately whole number fields with a language, time zone and duration do not support business rules so you can't leverage those. A potential workaround would be to write an onload javascript that could potentially clear the field if its null though I have not tested this.
    Doug Apicella
  • 3.  RE: Whole Number field with format Language
    Hi @Doug Apicella,
    Thank you for confirmation that this behaviour is specific with UCI. I have indeed tested business rules without success.
    I may go with Javascript then.
    Best Regards,​
    Laurent Maneville
    Nmédia
    Drummondville QC
