Is highlighting form fields with javascript or CSS supported? Dynamics 365
  • 1.  Is highlighting form fields with javascript or CSS supported? Dynamics 365
    We would like to highlight form fields on a form. Specifically, when a field is one of our business "key fields" as a visual cue to our users to obtain the information.
    I found these instructions (Coloring Fields in Dynamics CRM 2016 - QuantaCRM)
    document.getElementById("accountnumber_c").style.backgroundColor = "Yellow";
    Is such a method supported? Is there a better way that is supported?
    Adam Posegate
    Fox Valley Technical College
    Appleton WI
  • 2.  RE: Is highlighting form fields with javascript or CSS supported? Dynamics 365
    This approach is not supported. Soon all the developers get possibility to build own Custom Control (release of PowerApps Control Framework AKA PCF) and you will get possibility to do something like this using supported methods.
    Andrew Butenko
  • 3.  RE: Is highlighting form fields with javascript or CSS supported? Dynamics 365
    Edited by Rex Kenley Tan 14 days ago
    Adam
    Try this.
    1. Set the fields that you want to highlight as recommend using setRequiredLevel.
    2. Add a css file that would look for these "recommend tags" and highlight the next sibling control
    Rex Kenley Tan, MCP
    Tallmadge OH
  • 4.  RE: Is highlighting form fields with javascript or CSS supported? Dynamics 365
    Hi
    Agreed its not supported, some other options that come to mind that are supported:
    * Use a business process flow to highlight key fields
    * Use a webresource to either display a colour or image next to your fields
    * Use a webresource to summarise the fields you need completed at the top of the form
    * Use form notifications to summarise the fields you need completed
    Hope it helps. Cheers
    James Abraham
    Practice Lead, Dynamics
    Empired
