Flow triggering from wrong environment
  • 1.  Flow triggering from wrong environment
    The flows in Production are triggering from multiple environments.  I WAS using "current environment" but changed to specify the environment to try to break this apparent linkage,  but it does not help.
    It does not matter if the Flow exists in both environments or not.  It seems that the Production Flow is "seeing" the other environments.
    I was able to seemingly break the linkage on ONE flow by renaming it in the alternate environment, but this has not worked on the other flows.
    Any ideas on how/why this is happening and how to stop it?
    Paul Richards
    BlueCrest Inc
    Danbury
  • 2.  RE: Flow triggering from wrong environment
    Hi Paul,
    I recently had the behaviour that a flow was duplicated and I wasn't able to reach the duplicate. It ran and ran, noch chance to getin touch.
    Microsoft helped to delete the Flows.
    Seems that Flows are a little bit buggy overall, check out for still running deprecated flows, perhaps they are responsible. Make a ticket at Microsoft to get help deleteing them.
    I also had many situations were we have to wait for changes on triggers have to be reflected, sometimes also a recreation was needed.
    Marc
    Marc Lübberstedt
    SYCOR GmbH
    Göttingen
  • 3.  RE: Flow triggering from wrong environment
    Hi Paul, I have also experienced this issue and must say it is really scary not to be able to have proper ALM with flows. Particularly have flows triggered from power-apps (canvas) been buggy. I am happy to read these days that they are doing something with it in Wave 2 this year.
    Anyway, the solution for me is to always follow this procedure:
    1. Move the flow with solution (if it is not canvas PowerApp triggered, this was not supported last time I checked)
    2. Open the flow, change from Current Environment to a specific one and save the flow
    3. You might verify at this point that the flow is triggered in correct environment
    4. Change back to Current Environment trigger and save.
    Note that there are two CDS connectors, last one called CDS (current environment). I am not sure if they solved this problem in that one, but I read id might be a problem when you copy environment. I read that in this blog post https://saralagerquist.com/2019/12/15/cds-vs-cds-what-connector-should-i-use-in-power-automate/#:~:text=2.,on%20one%20event%20per%20flow
    Zarko Radevic
    Dynamics 365 developer
    Digitale Medier 1881 AS
  • 4.  RE: Flow triggering from wrong environment
    Posted 9 days ago
    I had something kind of similar, but in my case I was promoting the Flow from DEV to TEST environment, but the changes were not taking hold.  I ended up deleting the flow in TEST, then re-promoting it from DEV and it worked.
    Worth a shot.
    Chris Harrington
    Solutions Architect
    PowerObjects, an HCL Company
