Looping through Child records using JS
  • 1.  Looping through Child records using JS
    Hello
    Just wondering if anyone knows how to or has a link to a blog explaining how to (using JS) loop through child records of a contact record, checking the value of a Boolean attribute and then returning True/False if one of the records has the Boolean set true.
    Any advice much appreciated.
    James Rees
    Senior Systems Engineer
    Liverpool
  • 2.  RE: Looping through Child records using JS
    @James Rees
    I would first recommend the ​CRM REST Builder (https://github.com/jlattimer/CRMRESTBuilder) to help with building the WebAPI calls.
    I  would call the retrieveMultiple records WebAPI call for the entity you are wanting to check and pass reference to the contact, and additionally select the field you are wanting with a select statement. Similar to below. I used the connection entity as an example
    Xrm.WebApi.online.retrieveMultipleRecords("connection", "?$filter=_record1id_value eq GUID_Of_Contact").then(
        function success(results) {
            for (var i = 0; i < results.entities.length; i++) {
                    //Check Bool field
                var connectionid = results.entities[i]["connectionid"];
        function(error) {
            Xrm.Utility.alertDialog(error.message);
    Let me know if that helps!
    Erik Seitz
    RJ Corman Railroad Group, LLC
    Nicholasville KY
  • 3.  RE: Looping through Child records using JS
    Hey James,
    You could use a loop function but if you are just looking to see if any of the child records has a true value on a field, the Dynamics API now has a fetchxml query to save you the loops. Here is blog that discusses it: https://www.c-sharpcorner.com/article/execute-fetchxml-with-webapi-in-dynamics-365-using-javascript/. Once you return the value of your fetch you can check if the value is > 0 and develop your next steps from there.
    Doug Apicella
    Solution Architect
    Greenville SC
  • 4.  RE: Looping through Child records using JS
    Brilliant - Thanks both - I will see which works best for me.
    James Rees
    Liverpool John Moores University
    Liverpool
  • 5.  RE: Looping through Child records using JS
    James
    Try array.some().​​​
    https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Array/some
    let childRecords = [{checkMe: false}, {checkMe: false}, {checkMe: true}];
    console.log(childRecords.some(cr => cr.checkMe)); //true
    childRecords = [{checkMe: false}, {checkMe: false}, {checkMe: false}];
    console.log(childRecords.some(cr => cr.checkMe)); //false​
    Rex Kenley Tan, MCSA, MCSD
    Tallmadge OH
