Quick follow-up. I found my documentation on how I did this in the past where I added the Update to the installation. This was with CRM 2013, but from the documentation I read for Dynamics 365 v9 I believe it would work the same way. First step is to get the installation medium into C:\BIN\ and latest update. Then extract the update using this command:
C:\BIN\CRM2013-Server-KB2953252-ENU-amd64.exe /extract:C:\BIN\CRM2013_SP1_RU1
Create a new Text document with the following and save it as C:\BIN\CRM2013_Config.txt
<CRMSetup>
<Server>
<Patch update="true">C:\BIN\CRM2013_SP1_RU1\Server_KB2953252_amd64_1033.msp</Patch>
</Server>
</CRMSetup>
Execute this to start installation
C:\BIN\CRM2013\SetupServer.exe /config C:\BIN\CRM2013_Config.txt
The setup will show a window like this which shows the update has been applied:
Sam Alexander
Lead DBA Applications Analyst
Texas Farm Bureau Insurance
Waco TX
Sent: Nov 08, 2019 02:26 PM
Subject: Install v9 On Prem with Updates
I honestly try to avoid using the auto update during installation because this can cause our environments to be out of sync if we install them at different times. So if we build our environments over a few months the newer instances could be a few minor updates ahead of the first instance. Plus what if we have to rebuild an environment and need it to be on a specific version since that's what we've tested... I even try to have the prereq's installed ahead of time when possible as I know there are a fair number of them.
This is probably the route I'll try to go so I can guarantee our installation is identical in each environment.
https://docs.microsoft.com/en-us/dynamics365/customerengagement/on-premises/deploy/microsoft-dynamics-365-server-xml-configuration-file
Thanks for the feedback.
Sam Alexander
Waco TX
Sent: Nov 07, 2019 04:09 AM
I would expect an install of RTMv9 with SQL 2017 to work by selecting the option to update setup files during installation (but I have not tried this). Then you can install the D365 CE updates.
Feridun Kadir
Principal Consultant, MVP
Expert CRM Services Ltd
Stansted
Sent: Nov 06, 2019 01:06 PM
Per the documentation Dynamics 365 CE v9 On Prem does support SQL Server 2017 but only with Update 0.3. On an initial installation of v9 On Prem with SQL Server 2017 how can I install with the latest update (Currently 0.9) out of the gate so it'll have full support for SQL 2017? Or is there a suggested path to installing RTM v9 on SQL 2017 then running updates afterwards? I've injected updates into the initial CRM installation using an installation script years ago, but for the life of me I can't remember how I did it.
Sam Alexander
Waco TX
