Plug-in Trace Log V9 form, Message Block & Exception Details small
  • 1.  Plug-in Trace Log V9 form, Message Block & Exception Details small
    Posted 19 days ago
    Does anyone know how to increase the amount of lines on the Plug-in Trace Log form? Since v9 it has shrunk to be unusable. Right now we are forced with Copy Pasting the content over to a scratch file to read everything.
    Example:
    Mark Gugler
    Application Developer II
    Defenders
    Indianapolis IN
  • 2.  RE: Plug-in Trace Log V9 form, Message Block & Exception Details small
    Mark,
    I have also noticed that the space allocated for what arguably is the most important data on that form is way too small. I have switched over to using the Plugin Trace Viewer plugin and XrmToolbox (https://www.xrmtoolbox.com) to view my plugin trace logs. I particularly like the ability to be notified when new plugin logs are available. This way I don't need to keep refreshing the UI to see if my asynchronous plugins have finished running.
    Scott Golightly
    Senior Developer
    JourneyTEAM
    South Jordan UT
