Email To Case Fails To Create Case When Email Subject Is Blank
  • 1.  Email To Case Fails To Create Case When Email Subject Is Blank
    Posted Jan 30, 2020 12:11 PM
    Prior to this weekend, in version 9.1.0.11437 and earlier, our Email to Case process would create a Case even if the Email Subject was blank.  Once a User opened the Case record they would have to add a Case Title because it is a required field.  Since the minor update over the weekend to version 9.1.0.11732, the email comes into CRM but the Email to Case process no longer creates a Case.
    I could not find any reference to anything like this in the update release notes.  Has anyone else noticed this behavior?
    Thank you,
    Jim Corriveau
    A.W. Chesterton Company
    Groveland MA
  • 2.  RE: Email To Case Fails To Create Case When Email Subject Is Blank
    Posted Jan 30, 2020 03:38 PM
    The issue was a logic change between these 2 versions.  Previously I did not need to test to see if the subject was blank before checking to see if it contained a specific value, now i do.
    Thank you,
    Jim Corriveau
    Groveland MA
  • 3.  RE: Email To Case Fails To Create Case When Email Subject Is Blank
    Posted Jan 31, 2020 09:49 AM
    We are on version 9.1.0000.11732. I sent a test email to one of our shred mailboxes without a subject and it successfully created a case with blank case title...
    Anitha Vivekanandan
    Kavo Kerr Group
  • 4.  RE: Email To Case Fails To Create Case When Email Subject Is Blank
    Posted Feb 03, 2020 09:13 AM
    We are also on version 9.1.0.11733 but not seeing this issue. Emails with blank subjects are still being converted into cases with a blank Case Title. What error does the failed case creation workflow indicate?
    Marcus Cadena
    Crow Wing County
    Brainerd, Minnesota
